nagiosxi event_handler
lewislopez
Post by lewislopez »
I have the following cfg with event handler enabled. How can I prevent the event handler from running on warning. I only want it to execute on critical... ?? I still want to receive warning notification but I don't want the event handler to run on warning.
host_name altoona
service_description Check Proc CPU Usage
event_handler event_handler_oaprod_proc
event_handler_enabled 1
contacts mail_sa_altoona,mail_oaprod_24
check_command check_proc_cpu!12!15
kyang
Re: nagiosxi event_handler
Post by kyang »
You would need to add macros to your event handler.
This documentation gives you a few examples of what you could do to specify when an event handler should run. (Starting from page 9)
The macros would be $SERVICESTATE$ $SERVICESTATETYPE$ to specify when executing on critical.
