Thank!
Migration from Nagios 2008 v3.0.6 to Nagios XI
Hello , there is any possibility to migrate from a previews Nagios 2008 v3.0.6 to Nagios XI? My purpose is to do this operation without having to install the Nagios XI agents on every host and service. If there's any possibility please share this info with me
Thank!
Thank!
npolovenko
- Support Tech
Re: Migration from Nagios 2008 v3.0.6 to Nagios XI
@Hello, Bagz. What kind of agents do you have installed on hosts that you monitor? If those are nrpe agents than XI has a backward compatibility, so it should work just fine provided the IP of the nagios server stays the same.
You could also import all the config files to the XI so that way you won't need to create hosts/services definitions all over again. Take a look here: https://assets.nagios.com/downloads/nag ... ios_XI.pdf
