I defined email settings and enabled notifications alerts.
I can reconfigure hundreds of my defined services to define the notification alert settings, but is there a way I can define the email notification setting once in a service group and then make it effectively apply to all services that are member of that group?
this would save me ton of time, but I don't see where I can do this if possible.
thanks,
ik
email notification apply to service groups?
kyang
Re: email notification apply to service groups?
Take a look at XI Home --> Admin --> under "Users" click --> Notification Management
It's available if you have an enterprise edition of Nagios XI or a trial.
This allows you to deploy various notification settings to contacts or contact groups.
@kyang,
I see the default template, but I'm not sure what to do from there.
As an example I have a service group "Web Services" and contact group "Web Operations Group" which has number of contacts.
How do I make it so that all services that are part of "Web Services" sends out the notifications to the members of "Web Operations Group"?
Do I create a new template by modifying the Default notification template?
thanks,
ik
thanks,
ik
dwasswa
Hi @ikekim,
Please go to Configure >> Core Config Manager >> Bulk Modifications Tool
2.Click Add Contact Group(s) 3.Select a contact group under Contact Groups >> Services using Service Groups 4. Assign Contact Group to Service Group
In your use case Service group(Web Services) and Contact Group(Web Operations Group)
Lastly, save changes and Apply Configuration.
Apply those changes and let me know if that solves your issue.
npolovenko
- Support Tech
Thanks, @dwasswa!
@ikekim, Please let us know if you were able to resolve this problem and if you have any other questions.
