We have a check that is timing out due to long connection times to a particular server, Then when it goes critical it pages us. Could we adjust the alert to only email as opposed to page so that it does not continue to ping over the weekend?
Mind you this has contact groups which have 2 groups associated and I believe the page out is controlled from one of those groups.
I hope I made sense.
Email Alert even though Page out is configured
nexusguy59
- Former Nagios Staff
Re: Email Alert even though Page out is configured
You can definitely modify time periods: https://assets.nagios.com/downloads/nag ... ios-XI.pdf
It's hard to be more specific than the document at this point. Can you PM me your Profile? You can download it by going to Admin > System Config > System Profile and click the ***Download Profile*** button towards the top. If for whatever reason you *cannot* download the profile, please put the output of View System Info (5.3.4+, Show Profile if older) in the thread (that will at least get us some info). This will give us access to many of the logs we would otherwise ask for individually. If security is a concern, you can unzip the profile take out what you like, and then zip it up again. We may end up needing something you remove, but we can ask for that specifically.
You can also generate a profile manually using the script at /usr/local/nagiosxi/html/includes/components/profile/getprofile.sh
That should generate a profile in /usr/local/nagiosxi/var/components/ which you can get off the server with an application such as FileZilla.
If you get an error that PROFILE BUILD FAILED, please see https://support.nagios.com/kb/article.p ... ategory=44
