I have 2 windows server that were already set and being monitored for CPU/Memory/Disk space etc checks. They are set up identical to each other except the one is located on-site, the other is at our DR site (if that matters)
I wanted to add a new adhoc powershell script to check something on the servers. So I defined this check in the nrpecheck.cfg file as follows
host_name test,test2
service_description TLs check
check_command check_nrpe!TLSprotocol
check_interval 60
}Code: Select all
TLSprotocol = cmd /c echo scripts\\TLSprotocol.ps1; exit($lastexitcode) | powershell.exe -command-Restarted the NSClients, then reloaded the Nagios cor. I've done this previously and never had a problem.
This time however...
My new script was timing out on both servers no matter the time out interval. All previously set up checks on server "test2" also flagged with timeout warnings.
I removed all changes to both servers, and the new defined service from nagios and restarted the services. "test" returned to normal "test2" still timed out.
In addition, Any attempt to manually run a check off the nagiso cor server
such as
/usr/local/nagios/libexec/check_nrpe -H test2 -c alias_disk At this point I'm lost and I'm starting to think this is probably not a nagios specific problem, but I wanted to rule that out first!
Any help or points in the right direction would be appreciated.
Regards
