import failed with exclamation mark
pgh2011
Post by pgh2011 »
I've made some changes in the servicetemplate and I excluded some hosts.
In the configfile it writes: !servername, !servername2
When I want to import this file I get the following error:
1 items failed to import successfully Hide Details
!servername1,!servername2 - You must enter a proper host name. You can not use the characters: \~!$%^&*"'|<>?()=
How can I import this file?
kyang
Re: import failed with exclamation mark
Post by kyang »
Which service template did you change?
Can you post that service template and the changes you did that gave the error?
How did you import it the first time?
