Any problems using DNX on x86_64?
cwscribner
Post by cwscribner »
Hi all.
I'm looking into switching to DNX for an easier distributed monitoring setup. On the Nagios Wiki, the author noted that he had "severe issues" using DNX with x86_64 so I wanted to get some input from the forums. Has 64bit support gotten better for DNX or is this something that's not recommended?
Re: Any problems using DNX on x86_64?
It would be best to get this information directly from the author. The tech team here discussed it however we don't know what the DNX author had found, nor do we know if it has or has not been fixed.
