Moderator Edit: This thread has been split from another - https://support.nagios.com/forum/viewto ... f=6&t=8806
In the future, please create a new thread and link to the old one instead of adding on.
Hello Guys,
I'm with the same problem....I tried to up a new map image, but appears a error "attribute denifition out of object".
Could you help to fix this?
I need a manual with step by step. I'm afraid the situation will get worse if I type something wrong on linux.
NagVis Error - Attribute definition out of object
julianafernandesb
kyang
Re: NagVis Error - Attribute definition out of object
Which version of Nagios XI do you have?
Are you adding the NagVis map in XI Home --> Views also?
