INSTALLATION ERROR!
wyrit
INSTALLATION ERROR!
Post by wyrit »
centos 6.2
32 bit
nagios latest stable build,
manual install
INSTALLATION ERROR!
in your communications with Nagios XI technical support.
The script that failed was: './0-yum'
[Administrator@chi-compaq nagiosxi]$
Re: INSTALLATION ERROR!
Lets try running ./fullinstall again. If we get the same error we are going to have to investigate some files on the system...
the problem pertains to this line in the install log
error: can't create transaction lock on /var/lib/rpm/.rpm.lock (Permission denied)
It is possible that something else was locking it.
You are installing as root right?
wyrit
Post by wyrit »
@scottwilkersonran ./fullinstall and got the same error.
You are running this as root correct?
Can I have you post the results when you run
ls -l /var/lib/rpm/.rpm.lock
wyrit
Post by wyrit »
@scottwilkerson I wasn't running as root. I went ahead and ran as root and got past this error. Thanks. I did come up with a different error:
Error: Cannot retrieve metalink for repository: epel. Please verify its path and try again
Loaded plugins: fastestmirror, refresh-packagekit, security
Loading mirror speeds from cached hostfile
ERROR: centos-release-cr RPM was not installed - exiting.
RESULT=1
INSTALLATION ERROR!
Let me know if I need to start a new thread..
thanks
wyrit
Post by wyrit »
Ok I found the thread http://support.nagios.com/forum/viewtop ... ink#p20070 that addressed the Error I mentioned above. Thanks
I have another error that came up while running ./fullinstall
ERROR: Nagios Plugins install appears to have failed - exiting. Missing file = /usr/local/nagios/libexec/check_ping
ERROR: Subcomponent 'nagiosplugins' installation failed - exiting.
Subcomponents installation failed - exiting
RESULT=1
wyrit
Post by wyrit »
I browsed to /usr/local/nagios/libexec and noticed that check_ping was not in the folder. How do I get it?
It is possible that curl is not installed. Try:
# yum install -y curl
Then run the installer again.
