nagios log server 2.0.0 integer sorting problem
oginfra
Post by oginfra »
Dear Sir/Madam,
I can use increase or desc sorting of integer at nagios log server 1.4.4 when convert the field to integer.
but didn't work at version 2.0.0.
image: 2017-11-15_104221.png show our configuration in "Global config"
2017-11-23_172023.png show the result of sorting at version 2.0.0
cdienger
Re: nagios log server 2.0.0 integer sorting problem
Post by cdienger »
Hi Oginfra,
I see you've also opened a ticket regarding this. I've emailed you on the ticket to get troubleshoot this further.
