Nagios XI - ndo2db service will not start
Nagios XI 5.3.1 install - however the ndo2db service will not start - on Redhat 7
kyang
Re: Nagios XI - ndo2db service will not start
What are the error codes when you try to start ndo2db?
Could you try removing the lock file and then starting the service again?
Let us know if that worked for you.
rm -f /usr/local/nagios/var/ndo2db.lock
service ndo2db restartRe: Nagios XI - ndo2db service will not start
I upgraded from 5.3.1 to 5.4.11
And this sorted out the np2db service starting
kyang
Awesome!
Did you have any more questions or are we okay to lock this up?
Yes go ahead and lock this
Thanks again for all your help
kyang
Sounds good! I'll be closing this thread!
If you have any more questions, feel free to create another thread.
Thanks for using the Nagios Support Forum!
