The service critical status - Duration in Nagios is changing
nehal.salik
Post by nehal.salik »
The service critical status - Duration in Nagios is changing when refreshed
In my nagios environment , what happens is , whenever the nagios(3.2.1) is refreshed from the web , the checks which are in warning status, its duration changes.Sometimes it gives last 10 hour , sometimes it gives 1 day.Also the no of checks in the warning or critical state is changing, sometimes , it gives 230 in warning , then again when refreshed within 90 seconds , it shows 80 in warning state.Please help , I am not able to diagnose the problem.
Re: The service critical status - Duration in Nagios is chan
Post by dwhitfield »
Without more information, this would sound like normal function. It may be though that you are running to nagios processes.
What is the output of ps -aef | grep nagios.cfg?
Please run tar -zcvf /tmp/supporttar.tar.gz /usr/local/nagios/etc and send the resulting file. You won't be able to PM since this is your first post. If you don't want that information on the forum you can wait until you second post is approved and then you can PM it to me or another tecvh.
