define command
[email protected]
define command
Post by [email protected] »
Hi.
1- Is it possible to use check_disk plugin without to define a command under checkcommands.cfg ?
For example, if i have:
Under /etc/nagios/checkcommands.cfg:
command_name check_disk_all
command_line /usr/lib/nagios/plugins/check_disk -w $arg1$ -c $arg2$ -u GB
and under /etc/nagios/services.cfg:
host_name super
service_description disk checks
check_command check_disk_all!20%!10%
We can't use only a service like:
host_name super
check_command check_disk!20%!10%
2- This local command only check disk on nagios server. That is to say we have to copy "check_disk" plugin (or install plugins) on the computer that we need to check ??
TIA
Philippe
Re: define command
Post by dwhitfield »
If I understand your question correctly, that's the entire point of NRPE: https://assets.nagios.com/downloads/nag ... e/NRPE.pdf
Let us know if you need any help with installation of NRPE, or if that doesn't resolve your issue.
