If a server is down and alert is triggered from Nagios , there is a delay in alerts received by another ticketing tool with wrong time stamp.
Please refer the screenshot attached.
Alerts are getting generated on wrong time stamp.
raamardhani7
npolovenko
- Support Tech
Re: Alerts are getting generated on wrong time stamp.
Hello, @raamardhani7. Let's check whether your system time is out of sync with the php time. Please run the following commands in the command line and post the output:
and
dateCode: Select all
cat /etc/php.ini | grep date.timeAs of May 25th, 2018, all communications with Nagios Enterprises and its employees are covered under our new Privacy Policy.
raamardhani7
I have attached the output.
npolovenko
- Support Tech
@raamardhani7, Is your XI using PHP Sendmail? You can check in Admin/System Config/Manage Email Settings(left column). Can you send a test email from the same screen? Would the timestamp be incorrect? You can also try to change the PHP time zone from America/Chicago to US/Central in etc/php.ini.
