I am trying to troubleshoot an issue where on one of our MSSQL Clusters, when I query the SQL instance for checks using check_mssql_server.py, I get the following error:
<type 'exceptions.IndexError'>
Caught unexpected error. This could be caused by your sysperfinfo not containing the proper entries for this query, and you may delete this service check.One of the first things I thought to try based on the messages above was to look at nmap and see what the accessible ports were for each server. Here's the results:
NOT WORKING SERVER
Starting Nmap 6.25 ( http://nmap.org ) at 2017-11-27 14:24 EST
Nmap scan report for (not working server) (10.100.96.14)
Host is up (0.00043s latency).
Not shown: 986 closed ports
PORT STATE SERVICE
80/tcp open http
135/tcp open msrpc
139/tcp open netbios-ssn
445/tcp open microsoft-ds
1433/tcp open ms-sql-s
1556/tcp open veritas_pbx
2383/tcp open ms-olap4
2701/tcp open sms-rcinfo
3389/tcp open ms-wbt-server
5666/tcp open nrpe
13782/tcp open netbackup
49152/tcp open unknown
49153/tcp open unknown
49154/tcp open unknown
Nmap done: 1 IP address (1 host up) scanned in 2.48 secondsCode: Select all
Starting Nmap 6.25 ( http://nmap.org ) at 2017-11-27 16:04 EST
Nmap scan report for (working server) (10.100.8.34)
Host is up (0.00018s latency).
rDNS record for 10.100.8.34: (hidden)
Not shown: 978 closed ports
PORT STATE SERVICE
80/tcp open http
111/tcp open rpcbind
135/tcp open msrpc
1023/tcp open netvenuechat
2301/tcp open compaqdiag
2381/tcp open compaq-https
5666/tcp open nrpe
6129/tcp open unknown
8009/tcp open ajp13
8080/tcp open http-proxy
8443/tcp open https-alt
Nmap done: 1 IP address (1 host up) scanned in 1.57 seconds* The working server has an rDNS entry ... the non-working server doesn't.
* The working server has more open ports, but the port I would expect that we need for this to work, 1433, is open on both servers, so I don't think the differences in open ports matters a whole lot here.
Would love everyone's thought as to what I might be missing here. Thanks!
