HI
I have aproblem in Performance Graphs its suddenly not working form 27-11-2017 at 10:20 PM till now the message is No data to display
no changing happend in server and no problem in desk space as the following
I restart all Nagios server but nothing happened
[root@nagiosxi ~]# df -h
/dev/mapper/vg_nagiosxi-lv_root
169G 90G 72G 56% /
tmpfs 7.8G 12K 7.8G 1% /dev/shm
/dev/sda1 477M 94M 359M 21% /boot
/dev/mapper/vg_nagiosxi-lv_home
20G 8.0G 11G 44% /home
Performance Graphs suddenly Not working
Re: Performance Graphs suddenly Not working
Have you mad any changes to the system prior to seeing this issue, i.e. trying to implement a ramdisk?
What is the load on the system?
Is ncpd running?
In order to troubleshoot the issue, we would recommend that you follow the "Nagios XI - Performance Graph Problems" KB article here:
https://support.nagios.com/kb/article/n ... ems-9.html
Let us know if this helped you resolve the issue. Thank you!
uptimeCode: Select all
service npcd statushttps://support.nagios.com/kb/article/n ... ems-9.html
no any changes made; I return from vacation any I note that the Performance Graphs is working but its stopped again this morning
as the pig
I need the root case and I need to solve is we its working and stopped again
as the pig
npolovenko
- Support Tech
Hello, @paltel. I'd like to take a look at your System Profile.
To send us your system profile. Login to the Nagios XI GUI using a web browser.
Save the profile.zip file and attach it to your next forum post. Or you could upload it to the cloud storage of your choice and send me the link in PM.
