Moderator Edit: This thread has been split from another - https://support.nagios.com/forum/viewto ... =7&t=28821
In the future, please create a new thread and link to the old one instead of adding on.
Hi Team,
I am not getting the mail notifications from nagios.
In nagios logs we can see the below errors
[1512022520] SERVICE NOTIFICATION: nagiosadmin;localhost;HTTP;WARNING;notify-service-by-email;HTTP WARNING: HTTP/1.1 403 Forbidden - 4183 bytes in 0.002 second response time
[1512022520] wproc: NOTIFY job 1580 from worker Core Worker 27393 is a non-check helper but exited with return code 2
[1512022520] wproc: host=localhost; service=HTTP; contact=nagiosadmin
[1512022520] wproc: early_timeout=0; exited_ok=1; wait_status=512; error_code=0;
[1512022520] wproc: stderr line 01: /bin/sh: -c: line 0: unexpected EOF while looking for matching `"'
[1512022520] wproc: stderr line 02: /bin/sh: -c: line 1: syntax error: unexpected end of file
Please help me in resolving the issues.
Nagios not sending e-mail notification
Re: Nagios not sending e-mail notification
Do you see any config errors when you verify configuration?
Note: If the path to the binary and the main config file is different, please modify your command accordingly.
Can you post the definitions for the HTTP service on localhost, and all other relevant definitions, i.e. the service template used by HTTP (if any), contact/contact groups, notify-service-by-email, etc.?
Do you see any clues in the mail log?
/usr/local/nagios/bin/nagios -v /usr/local/nagios/etc/nagios.cfgCan you post the definitions for the HTTP service on localhost, and all other relevant definitions, i.e. the service template used by HTTP (if any), contact/contact groups, notify-service-by-email, etc.?
tail -100 /var/log/maillogBe sure to check out our Knowledgebase for helpful articles and solutions!
