Problem with freetds during yum update
jon.bilderback
Post by jon.bilderback »
Could someone help me get this package updated?
[root@nagios01r5v /]# yum update
Loaded plugins: fastestmirror
Loading mirror speeds from cached hostfile
* base: mirrors.igsobe.com
* epel: ftp.osuosl.org
* extras: mirror.thelinuxfix.com
* updates: centos-distro.cavecreek.net
Setting up Update Process
Resolving Dependencies
--> Running transaction check
--> Processing Dependency: libtds.so.5 for package: perl-DBD-Sybase
---> Package freetds.i386 0:0.91-1.el5 set to be updated
---> Package freetds-devel.i386 0:0.91-1.el5 set to be updated
perl-DBD-Sybase-1.10-1.el5.rf.i386 from installed has depsolving problems
--> Missing Dependency: libtds.so.5 is needed by package perl-DBD-Sybase-1.10-1.el5.rf.i386 (installed)
Error: Missing Dependency: libtds.so.5 is needed by package perl-DBD-Sybase-1.10-1.el5.rf.i386 (installed)
You could try using --skip-broken to work around the problem
You could try running: package-cleanup --problems
package-cleanup --dupes
rpm -Va --nofiles --nodigest
Re: Problem with freetds during yum update
This isn't a problem per-se, you can run
yum update --skip-broken
and all should be good
jon.bilderback
It is a problem per-se, or else I wouldn't have to skip-broken.
jon.bilderback wrote:It is a problem per-se, or else I wouldn't have to skip-broken.
What I meant by that is that dependency will not prevent Nagios XI from running in any fashion..
Especially since the missing dependency is already marked installed.
drakeu
Post by drakeu »
Were you able to get this upgraded? I tried using the --no-broken option but still received this error:
---> Package perl-DBD-Sybase.i386 0:1.10-1.el5.rf set to be updated
perl-DBD-Sybase-1.10-1.el5.rf.i386 from dag has depsolving problems
--> Missing Dependency: libtds.so.5 is needed by package perl-DBD-Sybase-1.10-1.el5.rf.i386 (dag)
Also if I do a search on the server for libtds.so.5 I can't find it. Can only find:
/usr/lib/libtdsodbc.so.0
/usr/lib/libtdsS.a
/usr/lib/libtdsS.so
/usr/lib/libtdsS.so.1.0.0
/usr/lib/libtdsodbc.so.0.0.0
Please advise. Thanks!
What version of Nagios XI are you running?
drakeu
Post by drakeu »
scottwilkerson wrote:What version of Nagios XI are you running?
2011R1.9
drakeu
Post by drakeu »
2011R1.9
I just saw in the 2011R2.0 release notes "Removed freetds and dbd dependencies", i'm guessing that may be the fix. I'll try upgrading and see what happens.
Go straight to 2011R2.1
2011R2.0 had some upgrade issues...
drakeu
Post by drakeu »
scottwilkerson wrote:Go straight to 2011R2.1
I finished the upgrade to 2011R2.1 but the same problem occurs when trying to use yum to install perl-DBD-Sybase.
