Can I use https://nagios.domain/nagiosxi/includes ... le=summary with multiple statement.
Like that https://nagios.domain/nagiosxi/includes ... L,CDM,TOTO[/u][/b]&style=summary
I want to see multiple hostgroup with the same URL.
Thank you!
Status.php multiple hostgroup style=summary
npolovenko
- Support Tech
Re: Status.php multiple hostgroup style=summary
Hello, @bennyboy. I don't think there's a way to do it like that. You can choose to display all host groups like this:
Another option would be to create a new host group that is going to include all objects from TEL,CDM,TOTO groups.
Or you may create a dashboard under Dashboards menu, then on the Home page in XI click on host group overview. And you'd just deploy multiple hostgroup summary dashlets to the dashboard. And at that point you can use the link to the dashboard instead(if your intention was to use it in the iframe)
- Former Nagios Staff
It sounds like this issue has been resolved. Is it okay if we lock this thread? Thanks for choosing the Nagios forums!
