I'm new to Nagios. We want to monitor--from Washington State--several remote Land Mobile Radio servers and routers in Alaska. They are currently running Centerity (but I can install Nagios.) However, our connection is a narrow satellite link from Alaska to Houston and bandwidth is precious. I have an idea to run the Nagios server locally and continuously monitor connectivity (ping) and heartbeat, but it would only utilize the sat link to send a critical event alert to the front-end. Here is a (very simple) Google slide of what I am trying to accomplish: https://docs.google.com/presentation/d/ ... sp=sharing. Feel free to add/edit the slide if you want.
So it is possible to configure the local Nagios server to send only user-specific events to a remote front-end? Would I need XI or will Core suffice? Any advice or guidance is appreciated. Thanks.
Receive only critical alerts from a remote server?
- Former Nagios Staff
Re: Receive only critical alerts from a remote server?
I'm not sure what you are trying to do. You talk about just doing criticals, but then you start talking about users.
You can do both if I understand, but for clarity "users" is an XI term and "contacts" is a Core term.
For example, the below has notification_options and contact_groups:
That's a host, so it has down, up, and recovery, rather than "critical" (which is for services), but service configs look similar.
define host {
host_name bogus-router
address 192.168.1.254
check_interval 5
retry_interval 1
max_check_attempts 5
check_period 24x7
contact_groups router-admins
notification_interval 30
notification_period 24x7
notification_options d,u,r
My bad, I meant a "generic" critical rather than a Critical. Language matters. Yea, I don't know enough to properly ask the question but you're example helps. I'll do some research over the weekend.dwhitfield wrote:I'm not sure what you are trying to do. You talk about just doing criticals, but then you start talking about users.
kyang
Sounds good,
Let us know if you have any more questions!
I hope this is more clarifying. As I said we have several remote Linux servers and Cisco routers in Alaska. My task is to simply monitor the host’s status (u,d,r) utilizing the absolute minimum bandwidth and display the dashboard (a minimalist dashboard would work if there is one) at our Washington site. As you can see from the diagram, our satellite link is a real bottleneck. Is it possible to configure the Nagios server to update the dashboard only when a host status changes? Maybe there is a better way to achieve this. Any input is appreciated.
- Link_diagram.pdf
- (65.73 KiB) Downloaded 322 times
npolovenko
- Support Tech
@aaronvan, So you'd probably have a Nagios Server in Alaska monitoring site A and site B, and you can configure it to send the results to another Nagios server in Washington via snmp traps. SNMP traps can be sent from Alaska to Washington only when a service check goes into critical, therefore minimizing a bandwidth data consumption. Nagios server in Washington would incorporate the results inside the dashboard that you could later import to the website.
Another solution would be to create a dashboard on the Nagios Server in Alaska and reroute that dashboard's URL to a public ip. So that later you could use it on the website inside the iframe.
