Output of Nagios Reports to a dashboard
rtausch
Post by rtausch »
Hello All,
So lets say I go to "Trends" on the bottom left side of the Nagios main page and I select it, then choose a Host and then pick a device. Then I select Report Options and then select Create Report. I can then see the State History over time for that device. Well my goal is to be able to take a number of devices and have them output to a dashboard of sorts that I can share on the web without having customers have to login into anything to see those devices. Is there a third party program that allows for this or a way to do it manually?
Many thanks for your help!
Rich
rtausch
Re: Output of Nagios Reports to a dashboard
Post by rtausch »
Anyone have any ideas???
