active directory
active directory
Is there a way to integrate ad logins with fusion 4?
Proudly running:
Nagios Network Analyser
Nagios Fusion
Nagios Fusion
kyang
Re: active directory
That is currently a feature request that is in the works. There is no current ETA on it.
It is under task_id=12510.
You could ask any one of us techs for an update in a few weeks if you would like.
Otherwise, did you have any other questions?
nah ok thanks lock it up
Proudly running:
Nagios Fusion
Nagios Fusion
bolson
Closing topic as resolved. Thank you for visiting the Nagios Support Forum.
