In the future, please create a new thread and link to the old one instead of adding on.
Hello All,
I am facing below error while installing the NagiosXI. Could you please check and revert..
I have read the other post and made changes on the server :
# grep -v ^# /etc/wgetrc
check_certificate = off
# grep -v ^# /etc/yum.conf
sslverify=false
[root@tx11nagiostestv ~]# rpm -qa wkhtmltox
wkhtmltox-0.12.2.1-1.x86_64
[root@tx11nagiostestv ~]# rpm -ql wkhtmltox
/usr/local/bin/wkhtmltoimage
/usr/local/bin/wkhtmltopdf
/usr/local/include/wkhtmltox/dllbegin.inc
/usr/local/include/wkhtmltox/dllend.inc
/usr/local/include/wkhtmltox/image.h
/usr/local/include/wkhtmltox/pdf.h
/usr/local/lib/libwkhtmltox.so
/usr/local/lib/libwkhtmltox.so.0
/usr/local/lib/libwkhtmltox.so.0.12
/usr/local/lib/libwkhtmltox.so.0.12.2
/usr/local/share/man/man1/wkhtmltoimage.1.gz
/usr/local/share/man/man1/wkhtmltopdf.1.gz
--2017-12-04 09:55:16-- https://assets.nagios.com/downloads/nag ... d64.tar.gz
Resolving assets.nagios.com... 72.14.181.71, 2600
Connecting to assets.nagios.com|72.14.181.71|:443... connected.
Unable to establish SSL connection.
ERROR: Subcomponent 'wkhtmlx' installation failed - exiting.
Subcomponents installation failed - exiting
RESULT=1
INSTALLATION ERROR!
in your communications with Nagios XI technical support.
The script that failed was: './A-subcomponents'
