Need To schedule Alerts on Particular time a day.
Arun Duggal
Post by Arun Duggal »
Support Team,
Please help to share the detail and config changes required to schedule alerts for particular time.
Re: Need To schedule Alerts on Particular time a day.
Post by mcapra »
Within your Host or Service configuration, you should be able to set the "check period" to whatever time you like. If you want a check to run from 08:00-09:00 every day, you would first define a timeperiod for that, then assign that timeperiod to the check's check_period.
I forget exactly where that all exists in the Core Config Manager though.
More info on check_period and timeperiods:
https://assets.nagios.com/downloads/nag ... riods.html
kyang
Post by kyang »
Thanks @mcapra!
The listed steps mcapra listed are great examples.
OP, Let us know if you have any more questions!
