Issue with environment Variable
ericssonvietnam
Post by ericssonvietnam »
Recently i have found the my home environment variable have changed and i am not able to reset it can you suggest how can i fix it without impacting my application.
-bash-4.1# echo $HOME
/usr/local/nagois/bin/
npolovenko
Re: Issue with environment Variable
Post by npolovenko »
Hello, @ericssonvietnam. You said it has changed? How did that happen? If you change the $HOME environment variable after Nagios was already installed you risk running into apache errors, and maybe more problems that would be hard to troubleshoot. What was the original value of the $HOME variable?
As far as the process of changing the home variable, take a look here:
https://stackoverflow.com/questions/207 ... -of-a-user
ericssonvietnam
npolovenko wrote:Hello, @ericssonvietnam. You said it has changed? How did that happen? If you change the $HOME environment variable after Nagios was already installed you risk running into apache errors, and maybe more problems that would be hard to troubleshoot. What was the original value of the $HOME variable?
issue is fixed now thanks
npolovenko
@ericssonvietnam, Sounds good. I'll close the thread.
