geting check rults on non-exist services for non-exist hosts
djohansen
Post by djohansen »
I have a problem with non-existant services reporting back check results on non-existant hosts..
We are running 5.4.7 on RHEL 7.4 and I keep getting the following in nagios.log:
[1512679643] Error: Got check result for service 'SNMP Traps' on host 'ilo-fsdb427.oa.caiso.com'. Unable to find service
[1512679702] Error: Got check result for service 'Local Swap Usage' on host 'apapmon16.wepex.net'. Unable to find service
[1512679703] Error: Got check result for service 'HTTP' on host 'apapmon16.wepex.net'. Unable to find service
[1512679743] Error: Got check result for service 'SSH' on host 'apapmon16.wepex.net'. Unable to find service
[1512679763] Error: Got check result for service 'Local Total Processes' on host 'apapmon16.wepex.net'. Unable to find service
No ghost files in either hosts/services.
The caveat here is that these hosts and services did exist at one time, and I started to clean up and this seemed to start.. but I ended up doing a restore_defaults.sh and repair_databases.sh and even rebooted to no avail. These seem to be "stuck" in the database??
Thx
djohansen
Re: geting check rults on non-exist services for non-exist h
Post by djohansen »
Solved..
Turned out I had outbound transfers set on another host which was trying to forward messages to my other host and not having the services present made Nagios unhappy with me.. I am working on a primary/secondary with two hosts for hot/cold operations
kyang
Post by kyang »
Sounds good!
Are there any more questions or are we okay to lock this up?
djohansen
Post by djohansen »
Lock 'er up!
NOT to be confused with "Lock HER up!!" ;)
kyang
Post by kyang »
Sounds good! I'll be closing this thread!
If you have any more questions, feel free to create another thread.
Thanks for using the Nagios Support Forum!
