I am using Nagios 3.3 and want to put the empty check_command in the hosts configuration , but unable to do so . If I do not put check_command in the host definition ,then those hosts status is marked as 'pending' .Is there a way I can have the hosts status as UP in the web interface.
Any suggestions how to achieve this ?
