MOD EDIT: Split from https://support.nagios.com/forum/viewto ... 1&start=10
can we ensure we can do all services under 1 host?
REST API is not having command end point.
matson-itops
- Former Nagios Staff
Re: REST API is not having command end point.
I don't understand your question in the context of the other thread. You are trying to add every new service to a host? What does that have to do with not being able to modify or not having a command end point?
Are you getting an error message? If so, what is it?
