Update URL after nagiosxi upgrade
rjmon
Post by rjmon »
I have upgraded nagiosxi to 5.4.7 and on my home/login page on the top left corner you will see nagiosxi logo when i click that link it takes me to the old url(from the old server). HOw do i update that url. I tried updating the file under scripts/nagiosql.login but still it is pointed to old url. When i say upgrade i mean i built this on a new server and imported all the configs and database to this one.
npolovenko
Re: Update URL after nagiosxi upgrade
Post by npolovenko »
Hello, @rjmon. First thing, can you go to the Admin menu, then System Config, System settings(left column), and make sure that the Program URL and the External URL are correct. After that please clear out the browsing data for this page in your browser, and try again. Let us know if the problem is still there.
rjmon
Post by rjmon »
The systems settings URL and the site URL are same. Cleared the cache and it is still pointed to the old URL
npolovenko
@rjmon, Please go to the Admin menu, then System Extensions(in the left column), then Manage Components. In the list find the "Custom Logo Component", and click on the Edit Settings(wrench icon). Insert the correct target URL, click on Enable Custom Logo and Apply Settings.
Let us know if that fixed it.
rjmon
Post by rjmon »
Thanks. That did the trick.
npolovenko
@rjmon, Great, closing this thread as resolved.
