check_init_service error
felipethea
Post by felipethea »
I'm new to Nagios and I'm trying out Nagios XI demo.
I setup a simple Ubuntu 16.04 server to monitor and I installed the linux nrpe agent using the installer given by the Nagios XI GUI.
The install of the nrpe agent worked fine and I'm able to monitor cpu/processes/and load.
However, I'm not able to do a service check.
I get the following error message:
ERROR: No service name specified on command line
one of the services that I'm checking is apache2
the command used is
check_nrpe!check_init_service!-a 'apache2'
What am I missing?
Thank you
felipethea
Re: check_init_service error
I re-installed the nrpe agent and check_init_service started working
Thank you
kyang
Post by kyang »
Sounds good! I'll be closing this thread!
If you have any more questions, feel free to create another thread.
Thanks for using the Nagios Support Forum!
