WMI Monitoring - Auto-Discover hosts?
kelemvor
Post by kelemvor »
We just installed Nagios XI to test it out. I was able to successfully setup a single host using the WMI Wizard which is nice. Teh next step is I'd like Nagios to scan an IP range and find all the hosts and use the same WMI settings for all of them so I don't have to set them up manually.
I went to the Auto-Discover section and can have it scan and find hosts but I don't see how to tell it to use the WMI settings to query them.
Can anyone direct me to how that can be done?
Thanks!
npolovenko
Re: WMI Monitoring - Auto-Discover hosts?
Post by npolovenko »
Hello, @kelemvor.
You could run a wizard against one of the VM's manually. After that you'd go to the Core Configuration Manager, then Bulk Modifications Tool, click on "Add Services". Select the services created by the VMware wizard. Click on "select hosts" and select all the hosts that you added using the autodiscovery wizard. Click on Save Changes, and then Apply Configuration.
