I have a specific service that I would like to report as a warning when stopped, rather than critical. Based on some research, it looked like I was not able to achieve this using check_nt. I'm trying check_nrpe with the following command:
What timezone are you in? I just want to understand this log file better.
You may need to allow nasty_meta_characters in your nsclient.ini. Can you post that for review? If you make the change, make sure you restart NSClient after doing so.
I am US eastern. I believe I've added an exception for nasty_meta_characters. I've upgraded to 0.4.4.23 and I'm receiving the same error. .ini file attached.
I made the change to the ini file and restarted the service. I made the adjustment to the check as you indicated but I'm having issues. Do I need to add in an ARG4 and split up the code for ARG3?
@moweryd, NRPE has always had problems recognizing quotes within quotes. A quick way around your problem would be to create a new command in CCM. If you define the command as on my screenshot you'd just pass the check name in ARG1 and a service name in ARG2.
Let me know if you think that would work for you.
