Nagios: Problem with External Command
brauh4
Post by brauh4 »
Hello everyone, I would like to see if anyone can help me.
I am with the following error in Nagios:
Error: Could not stat () command file '/ usr / local / nagios / var / rw / nagios.cmd'!
The external command file May be missing, Nagios May Not be running, and / or Nagios May Not be checking external commands.
An error occurred while Attempting to commit your command for processing.
Note: Nagios running on CENTOS 6, already follow some topics dealing with the matter, but did not succeed.
nscott
Re: Nagios: Problem with External Command
Post by nscott »
Can you see if Nagios Core is actually running?
/etc/init.d/nagios status
It usually gives that error when the service isn't running because the command pipe doesn't exist.
Nicholas Scott
brauh4
Post by brauh4 »
Yes, everything is working perfectly.
But the browser does not respond to external commands. = /
mguthrie
Post by mguthrie »
Make sure that external commands are enabled in the main nagios.cfg file.
