Nagios Fusion is out of space
This support forum board is for questions relating to Nagios Fusion.
dlukinski
Post by dlukinski »
Our Nagios Fusion ran out of space (month past the implementation)
How to cleanup?
[root@fikc-nagfsprod01 ~]# df -h
/dev/mapper/VolGroup-lv_root
37G 35G 85M 100% /
tmpfs 939M 0 939M 0% /dev/shm
/dev/sda1 477M 95M 357M 22% /boot
Thank you
npolovenko
Re: Nagios Fusion is out of space
Post by npolovenko »
@dlukinski, How many servers does this Fusion poll the data from? How many services and hosts are monitored? Nagios Fusion collects and renders a lot of data from the Fused servers, so if you're monitoring thousands of hosts and services 35GB database is normal.
What you could do is go to the system settings, then select Data&Polling and lower the data retention period. Use this article as a reference:
https://assets.nagios.com/downloads/nag ... gJ8dPD_BwE
Also, if you click on the "Servers" menu, and click on settings next to the individual fused server, you'll see a checkbox that says Ignore XI host/service meta data.
You can check that box to potentially lower the disk consumption as well.
Other than that I'd consider adding more storage space.
dlukinski
Post by dlukinski »
npolovenko wrote:@dlukinski, How many servers does this Fusion poll the data from? How many services and hosts are monitored? Nagios Fusion collects and renders a lot of data from the Fused servers, so if you're monitoring thousands of hosts and services 35GB database is normal.
So we were given incorrect info when asked Nagios Support to help installing & sizing Fusion.
How to extend Fusion disk space?
bolson
Post by bolson »
This document will guide you through the process of resizing your Nagios Fusion VM disk:
https://assets.nagios.com/downloads/nag ... M-Disk.pdf
dlukinski
Post by dlukinski »
bolson wrote:This document will guide you through the process of resizing your Nagios Fusion VM disk:
This is now resolved, please close
