MRTG and Net_SNMP_util.pm file looks for nonexisting hosts
sathevaner
Post by sathevaner »
Good morning,
Ever since the MRTG script started running this morning on our Nagios XI server, there is an SNMPGET problem for 2 hosts which don't exist anymore. It's as if the server doesn't see the right version of the database. Here is the output:
SNMPGET Problem for ifHCInOctets.1 ifHCOutOctets.1 on [email protected]:161::::2:v4only: No response from remote host '10.78.2.81' at /usr/bin/../lib/mrtg2/Net_SNMP_util.pm line 594
	Net_SNMP_util::snmpget('[email protected]:161::::2:v4only', 'HASH(0x23ac370)', 'ifHCInOctets.1', 'ifHCOutOctets.1') called at /usr/bin/mrtg line 2330
	main::getsnmparg('HASH(0x15dd050)', 'HASH(0x23b08e0)', 'HASH(0x14d2818)', 'HASH(0x1979c18)') called at /usr/bin/mrtg line 2510
	main::readtargets('HASH(0x15dd050)', 'ARRAY(0x1649310)', 'HASH(0x14d2818)') called at /usr/bin/mrtg line 403
	main::main called at /usr/bin/mrtg line 143
2017-12-29 09:30:03: WARNING: skipping because at least the query for ifHCInOctets.1 on  10.78.2.81 did not succeed
2017-12-29 09:30:03: WARNING: no data for ifHCInOctets&ifHCOutOctets:[email protected]. Skipping further queries for Host 10.78.2.81 in this round.
SNMPGET Problem for ifHCInOctets.1 ifHCOutOctets.1 on [email protected]:161::::2:v4only: No response from remote host '10.78.2.80' at /usr/bin/../lib/mrtg2/Net_SNMP_util.pm line 594
	Net_SNMP_util::snmpget('[email protected]:161::::2:v4only', 'HASH(0x23eeaf8)', 'ifHCInOctets.1', 'ifHCOutOctets.1') called at /usr/bin/mrtg line 2330
	main::getsnmparg('HASH(0x15dd050)', 'HASH(0x23ef170)', 'HASH(0x14d2818)', 'HASH(0x1979c18)') called at /usr/bin/mrtg line 2510
2017-12-29 09:30:03: WARNING: skipping because at least the query for ifHCInOctets.1 on  10.78.2.80 did not succeed
2017-12-29 09:30:03: WARNING: no data for ifHCInOctets&ifHCOutOctets:[email protected]. Skipping further queries for Host 10.78.2.80 in this round.
2017-12-29 09:30:24: ERROR: Target[10.78.2.81_1][_IN_] ' $target->[841]{$mode} ' did not eval into defined data
2017-12-29 09:30:24: ERROR: Target[10.78.2.81_1][_OUT_] ' $target->[841]{$mode} ' did not eval into defined data
2017-12-29 09:30:24: ERROR: Target[10.78.2.81_2][_IN_] ' $target->[842]{$mode} ' did not eval into defined data
2017-12-29 09:30:24: ERROR: Target[10.78.2.81_2][_OUT_] ' $target->[842]{$mode} ' did not eval into defined data
2017-12-29 09:30:24: ERROR: Target[10.78.2.81_3][_IN_] ' $target->[843]{$mode} ' did not eval into defined data
2017-12-29 09:30:24: ERROR: Target[10.78.2.81_3][_OUT_] ' $target->[843]{$mode} ' did not eval into defined data
2017-12-29 09:30:24: ERROR: Target[10.78.2.81_4][_IN_] ' $target->[844]{$mode} ' did not eval into defined data
2017-12-29 09:30:24: ERROR: Target[10.78.2.81_4][_OUT_] ' $target->[844]{$mode} ' did not eval into defined data
2017-12-29 09:30:24: ERROR: Target[10.78.2.81_5][_IN_] ' $target->[845]{$mode} ' did not eval into defined data
2017-12-29 09:30:24: ERROR: Target[10.78.2.81_5][_OUT_] ' $target->[845]{$mode} ' did not eval into defined data
2017-12-29 09:30:24: ERROR: Target[10.78.2.81_6][_IN_] ' $target->[846]{$mode} ' did not eval into defined data
2017-12-29 09:30:24: ERROR: Target[10.78.2.81_6][_OUT_] ' $target->[846]{$mode} ' did not eval into defined data
2017-12-29 09:30:24: ERROR: Target[10.78.2.81_7][_IN_] ' $target->[847]{$mode} ' did not eval into defined data
2017-12-29 09:30:24: ERROR: Target[10.78.2.81_7][_OUT_] ' $target->[847]{$mode} ' did not eval into defined data
2017-12-29 09:30:24: ERROR: Target[10.78.2.81_8][_IN_] ' $target->[848]{$mode} ' did not eval into defined data
2017-12-29 09:30:24: ERROR: Target[10.78.2.81_8][_OUT_] ' $target->[848]{$mode} ' did not eval into defined data
2017-12-29 09:30:24: ERROR: Target[10.78.2.81_9][_IN_] ' $target->[849]{$mode} ' did not eval into defined data
2017-12-29 09:30:24: ERROR: Target[10.78.2.81_9][_OUT_] ' $target->[849]{$mode} ' did not eval into defined data
2017-12-29 09:30:24: ERROR: Target[10.78.2.81_10][_IN_] ' $target->[850]{$mode} ' did not eval into defined data
2017-12-29 09:30:24: ERROR: Target[10.78.2.81_10][_OUT_] ' $target->[850]{$mode} ' did not eval into defined data
2017-12-29 09:30:24: ERROR: Target[10.78.2.81_11][_IN_] ' $target->[851]{$mode} ' did not eval into defined data
2017-12-29 09:30:24: ERROR: Target[10.78.2.81_11][_OUT_] ' $target->[851]{$mode} ' did not eval into defined data
2017-12-29 09:30:24: ERROR: Target[10.78.2.81_12][_IN_] ' $target->[852]{$mode} ' did not eval into defined data
2017-12-29 09:30:24: ERROR: Target[10.78.2.81_12][_OUT_] ' $target->[852]{$mode} ' did not eval into defined data
2017-12-29 09:30:24: ERROR: Target[10.78.2.81_13][_IN_] ' $target->[853]{$mode} ' did not eval into defined data
2017-12-29 09:30:24: ERROR: Target[10.78.2.81_13][_OUT_] ' $target->[853]{$mode} ' did not eval into defined data
2017-12-29 09:30:24: ERROR: Target[10.78.2.81_14][_IN_] ' $target->[854]{$mode} ' did not eval into defined data
2017-12-29 09:30:24: ERROR: Target[10.78.2.81_14][_OUT_] ' $target->[854]{$mode} ' did not eval into defined data
2017-12-29 09:30:24: ERROR: Target[10.78.2.81_15][_IN_] ' $target->[855]{$mode} ' did not eval into defined data
2017-12-29 09:30:24: ERROR: Target[10.78.2.81_15][_OUT_] ' $target->[855]{$mode} ' did not eval into defined data
2017-12-29 09:30:24: ERROR: Target[10.78.2.81_16][_IN_] ' $target->[856]{$mode} ' did not eval into defined data
2017-12-29 09:30:24: ERROR: Target[10.78.2.81_16][_OUT_] ' $target->[856]{$mode} ' did not eval into defined data
2017-12-29 09:30:24: ERROR: Target[10.78.2.81_17][_IN_] ' $target->[857]{$mode} ' did not eval into defined data
2017-12-29 09:30:24: ERROR: Target[10.78.2.81_17][_OUT_] ' $target->[857]{$mode} ' did not eval into defined data
2017-12-29 09:30:24: ERROR: Target[10.78.2.81_18][_IN_] ' $target->[858]{$mode} ' did not eval into defined data
2017-12-29 09:30:24: ERROR: Target[10.78.2.81_18][_OUT_] ' $target->[858]{$mode} ' did not eval into defined data
2017-12-29 09:30:24: ERROR: Target[10.78.2.81_19][_IN_] ' $target->[859]{$mode} ' did not eval into defined data
2017-12-29 09:30:24: ERROR: Target[10.78.2.81_19][_OUT_] ' $target->[859]{$mode} ' did not eval into defined data
2017-12-29 09:30:24: ERROR: Target[10.78.2.81_20][_IN_] ' $target->[860]{$mode} ' did not eval into defined data
2017-12-29 09:30:24: ERROR: Target[10.78.2.81_20][_OUT_] ' $target->[860]{$mode} ' did not eval into defined data
2017-12-29 09:30:24: ERROR: Target[10.78.2.81_21][_IN_] ' $target->[861]{$mode} ' did not eval into defined data
2017-12-29 09:30:24: ERROR: Target[10.78.2.81_21][_OUT_] ' $target->[861]{$mode} ' did not eval into defined data
2017-12-29 09:30:24: ERROR: Target[10.78.2.81_22][_IN_] ' $target->[862]{$mode} ' did not eval into defined data
2017-12-29 09:30:24: ERROR: Target[10.78.2.81_22][_OUT_] ' $target->[862]{$mode} ' did not eval into defined data
2017-12-29 09:30:24: ERROR: Target[10.78.2.81_23][_IN_] ' $target->[863]{$mode} ' did not eval into defined data
2017-12-29 09:30:24: ERROR: Target[10.78.2.81_23][_OUT_] ' $target->[863]{$mode} ' did not eval into defined data
2017-12-29 09:30:24: ERROR: Target[10.78.2.81_24][_IN_] ' $target->[864]{$mode} ' did not eval into defined data
2017-12-29 09:30:24: ERROR: Target[10.78.2.81_24][_OUT_] ' $target->[864]{$mode} ' did not eval into defined data
2017-12-29 09:30:24: ERROR: Target[10.78.2.81_25][_IN_] ' $target->[865]{$mode} ' did not eval into defined data
2017-12-29 09:30:24: ERROR: Target[10.78.2.81_25][_OUT_] ' $target->[865]{$mode} ' did not eval into defined data
2017-12-29 09:30:24: ERROR: Target[10.78.2.81_26][_IN_] ' $target->[866]{$mode} ' did not eval into defined data
2017-12-29 09:30:24: ERROR: Target[10.78.2.81_26][_OUT_] ' $target->[866]{$mode} ' did not eval into defined data
2017-12-29 09:30:24: ERROR: Target[10.78.2.81_27][_IN_] ' $target->[867]{$mode} ' did not eval into defined data
2017-12-29 09:30:24: ERROR: Target[10.78.2.81_27][_OUT_] ' $target->[867]{$mode} ' did not eval into defined data
2017-12-29 09:30:24: ERROR: Target[10.78.2.81_28][_IN_] ' $target->[868]{$mode} ' did not eval into defined data
2017-12-29 09:30:24: ERROR: Target[10.78.2.81_28][_OUT_] ' $target->[868]{$mode} ' did not eval into defined data
2017-12-29 09:30:24: ERROR: Target[10.78.2.81_29][_IN_] ' $target->[869]{$mode} ' did not eval into defined data
2017-12-29 09:30:24: ERROR: Target[10.78.2.81_29][_OUT_] ' $target->[869]{$mode} ' did not eval into defined data
2017-12-29 09:30:24: ERROR: Target[10.78.2.81_30][_IN_] ' $target->[870]{$mode} ' did not eval into defined data
2017-12-29 09:30:24: ERROR: Target[10.78.2.81_30][_OUT_] ' $target->[870]{$mode} ' did not eval into defined data
2017-12-29 09:30:24: ERROR: Target[10.78.2.81_31][_IN_] ' $target->[871]{$mode} ' did not eval into defined data
2017-12-29 09:30:24: ERROR: Target[10.78.2.81_31][_OUT_] ' $target->[871]{$mode} ' did not eval into defined data
2017-12-29 09:30:24: ERROR: Target[10.78.2.81_32][_IN_] ' $target->[872]{$mode} ' did not eval into defined data
2017-12-29 09:30:24: ERROR: Target[10.78.2.81_32][_OUT_] ' $target->[872]{$mode} ' did not eval into defined data
2017-12-29 09:30:24: ERROR: Target[10.78.2.81_33][_IN_] ' $target->[873]{$mode} ' did not eval into defined data
2017-12-29 09:30:24: ERROR: Target[10.78.2.81_33][_OUT_] ' $target->[873]{$mode} ' did not eval into defined data
2017-12-29 09:30:24: ERROR: Target[10.78.2.81_34][_IN_] ' $target->[874]{$mode} ' did not eval into defined data
2017-12-29 09:30:24: ERROR: Target[10.78.2.81_34][_OUT_] ' $target->[874]{$mode} ' did not eval into defined data
2017-12-29 09:30:24: ERROR: Target[10.78.2.81_35][_IN_] ' $target->[875]{$mode} ' did not eval into defined data
2017-12-29 09:30:24: ERROR: Target[10.78.2.81_35][_OUT_] ' $target->[875]{$mode} ' did not eval into defined data
2017-12-29 09:30:24: ERROR: Target[10.78.2.81_36][_IN_] ' $target->[876]{$mode} ' did not eval into defined data
2017-12-29 09:30:24: ERROR: Target[10.78.2.81_36][_OUT_] ' $target->[876]{$mode} ' did not eval into defined data
2017-12-29 09:30:24: ERROR: Target[10.78.2.81_37][_IN_] ' $target->[877]{$mode} ' did not eval into defined data
2017-12-29 09:30:24: ERROR: Target[10.78.2.81_37][_OUT_] ' $target->[877]{$mode} ' did not eval into defined data
2017-12-29 09:30:24: ERROR: Target[10.78.2.81_38][_IN_] ' $target->[878]{$mode} ' did not eval into defined data
2017-12-29 09:30:24: ERROR: Target[10.78.2.81_38][_OUT_] ' $target->[878]{$mode} ' did not eval into defined data
2017-12-29 09:30:24: ERROR: Target[10.78.2.81_39][_IN_] ' $target->[879]{$mode} ' did not eval into defined data
2017-12-29 09:30:24: ERROR: Target[10.78.2.81_39][_OUT_] ' $target->[879]{$mode} ' did not eval into defined data
2017-12-29 09:30:24: ERROR: Target[10.78.2.81_40][_IN_] ' $target->[880]{$mode} ' did not eval into defined data
2017-12-29 09:30:24: ERROR: Target[10.78.2.81_40][_OUT_] ' $target->[880]{$mode} ' did not eval into defined data
2017-12-29 09:30:24: ERROR: Target[10.78.2.81_41][_IN_] ' $target->[881]{$mode} ' did not eval into defined data
2017-12-29 09:30:24: ERROR: Target[10.78.2.81_41][_OUT_] ' $target->[881]{$mode} ' did not eval into defined data
2017-12-29 09:30:24: ERROR: Target[10.78.2.81_42][_IN_] ' $target->[882]{$mode} ' did not eval into defined data
2017-12-29 09:30:24: ERROR: Target[10.78.2.81_42][_OUT_] ' $target->[882]{$mode} ' did not eval into defined data
2017-12-29 09:30:24: ERROR: Target[10.78.2.81_43][_IN_] ' $target->[883]{$mode} ' did not eval into defined data
2017-12-29 09:30:24: ERROR: Target[10.78.2.81_43][_OUT_] ' $target->[883]{$mode} ' did not eval into defined data
2017-12-29 09:30:24: ERROR: Target[10.78.2.81_44][_IN_] ' $target->[884]{$mode} ' did not eval into defined data
2017-12-29 09:30:24: ERROR: Target[10.78.2.81_44][_OUT_] ' $target->[884]{$mode} ' did not eval into defined data
2017-12-29 09:30:24: ERROR: Target[10.78.2.81_45][_IN_] ' $target->[885]{$mode} ' did not eval into defined data
2017-12-29 09:30:24: ERROR: Target[10.78.2.81_45][_OUT_] ' $target->[885]{$mode} ' did not eval into defined data
2017-12-29 09:30:24: ERROR: Target[10.78.2.81_46][_IN_] ' $target->[886]{$mode} ' did not eval into defined data
2017-12-29 09:30:24: ERROR: Target[10.78.2.81_46][_OUT_] ' $target->[886]{$mode} ' did not eval into defined data
2017-12-29 09:30:24: ERROR: Target[10.78.2.81_47][_IN_] ' $target->[887]{$mode} ' did not eval into defined data
2017-12-29 09:30:24: ERROR: Target[10.78.2.81_47][_OUT_] ' $target->[887]{$mode} ' did not eval into defined data
2017-12-29 09:30:24: ERROR: Target[10.78.2.81_48][_IN_] ' $target->[888]{$mode} ' did not eval into defined data
2017-12-29 09:30:24: ERROR: Target[10.78.2.81_48][_OUT_] ' $target->[888]{$mode} ' did not eval into defined data
2017-12-29 09:30:24: ERROR: Target[10.78.2.81_49][_IN_] ' $target->[889]{$mode} ' did not eval into defined data
2017-12-29 09:30:24: ERROR: Target[10.78.2.81_49][_OUT_] ' $target->[889]{$mode} ' did not eval into defined data
2017-12-29 09:30:24: ERROR: Target[10.78.2.81_50][_IN_] ' $target->[890]{$mode} ' did not eval into defined data
2017-12-29 09:30:24: ERROR: Target[10.78.2.81_50][_OUT_] ' $target->[890]{$mode} ' did not eval into defined data
2017-12-29 09:30:24: ERROR: Target[10.78.2.81_51][_IN_] ' $target->[891]{$mode} ' did not eval into defined data
2017-12-29 09:30:24: ERROR: Target[10.78.2.81_51][_OUT_] ' $target->[891]{$mode} ' did not eval into defined data
2017-12-29 09:30:24: ERROR: Target[10.78.2.81_52][_IN_] ' $target->[892]{$mode} ' did not eval into defined data
2017-12-29 09:30:24: ERROR: Target[10.78.2.81_52][_OUT_] ' $target->[892]{$mode} ' did not eval into defined data
2017-12-29 09:30:24: ERROR: Target[10.78.2.81_417][_IN_] ' $target->[893]{$mode} ' did not eval into defined data
2017-12-29 09:30:24: ERROR: Target[10.78.2.81_417][_OUT_] ' $target->[893]{$mode} ' did not eval into defined data
2017-12-29 09:30:24: ERROR: Target[10.78.2.81_418][_IN_] ' $target->[894]{$mode} ' did not eval into defined data
2017-12-29 09:30:24: ERROR: Target[10.78.2.81_418][_OUT_] ' $target->[894]{$mode} ' did not eval into defined data
2017-12-29 09:30:24: ERROR: Target[10.78.2.81_419][_IN_] ' $target->[895]{$mode} ' did not eval into defined data
2017-12-29 09:30:24: ERROR: Target[10.78.2.81_419][_OUT_] ' $target->[895]{$mode} ' did not eval into defined data
2017-12-29 09:30:24: ERROR: Target[10.78.2.81_420][_IN_] ' $target->[896]{$mode} ' did not eval into defined data
2017-12-29 09:30:24: ERROR: Target[10.78.2.81_420][_OUT_] ' $target->[896]{$mode} ' did not eval into defined data
2017-12-29 09:30:24: ERROR: Target[10.78.2.81_421][_IN_] ' $target->[897]{$mode} ' did not eval into defined data
2017-12-29 09:30:24: ERROR: Target[10.78.2.81_421][_OUT_] ' $target->[897]{$mode} ' did not eval into defined data
2017-12-29 09:30:24: ERROR: Target[10.78.2.81_422][_IN_] ' $target->[898]{$mode} ' did not eval into defined data
2017-12-29 09:30:24: ERROR: Target[10.78.2.81_422][_OUT_] ' $target->[898]{$mode} ' did not eval into defined data
2017-12-29 09:30:24: ERROR: Target[10.78.2.81_423][_IN_] ' $target->[899]{$mode} ' did not eval into defined data
2017-12-29 09:30:24: ERROR: Target[10.78.2.81_423][_OUT_] ' $target->[899]{$mode} ' did not eval into defined data
2017-12-29 09:30:24: ERROR: Target[10.78.2.80_1][_IN_] ' $target->[900]{$mode} ' did not eval into defined data
2017-12-29 09:30:24: ERROR: Target[10.78.2.80_1][_OUT_] ' $target->[900]{$mode} ' did not eval into defined data
2017-12-29 09:30:24: ERROR: Target[10.78.2.80_2][_IN_] ' $target->[901]{$mode} ' did not eval into defined data
2017-12-29 09:30:24: ERROR: Target[10.78.2.80_2][_OUT_] ' $target->[901]{$mode} ' did not eval into defined data
2017-12-29 09:30:24: ERROR: Target[10.78.2.80_3][_IN_] ' $target->[902]{$mode} ' did not eval into defined data
2017-12-29 09:30:24: ERROR: Target[10.78.2.80_3][_OUT_] ' $target->[902]{$mode} ' did not eval into defined data
2017-12-29 09:30:24: ERROR: Target[10.78.2.80_4][_IN_] ' $target->[903]{$mode} ' did not eval into defined data
2017-12-29 09:30:24: ERROR: Target[10.78.2.80_4][_OUT_] ' $target->[903]{$mode} ' did not eval into defined data
2017-12-29 09:30:24: ERROR: Target[10.78.2.80_5][_IN_] ' $target->[904]{$mode} ' did not eval into defined data
2017-12-29 09:30:24: ERROR: Target[10.78.2.80_5][_OUT_] ' $target->[904]{$mode} ' did not eval into defined data
2017-12-29 09:30:24: ERROR: Target[10.78.2.80_6][_IN_] ' $target->[905]{$mode} ' did not eval into defined data
2017-12-29 09:30:24: ERROR: Target[10.78.2.80_6][_OUT_] ' $target->[905]{$mode} ' did not eval into defined data
2017-12-29 09:30:24: ERROR: Target[10.78.2.80_7][_IN_] ' $target->[906]{$mode} ' did not eval into defined data
2017-12-29 09:30:24: ERROR: Target[10.78.2.80_7][_OUT_] ' $target->[906]{$mode} ' did not eval into defined data
2017-12-29 09:30:24: ERROR: Target[10.78.2.80_8][_IN_] ' $target->[907]{$mode} ' did not eval into defined data
2017-12-29 09:30:24: ERROR: Target[10.78.2.80_8][_OUT_] ' $target->[907]{$mode} ' did not eval into defined data
2017-12-29 09:30:24: ERROR: Target[10.78.2.80_9][_IN_] ' $target->[908]{$mode} ' did not eval into defined data
2017-12-29 09:30:24: ERROR: Target[10.78.2.80_9][_OUT_] ' $target->[908]{$mode} ' did not eval into defined data
2017-12-29 09:30:24: ERROR: Target[10.78.2.80_10][_IN_] ' $target->[909]{$mode} ' did not eval into defined data
2017-12-29 09:30:24: ERROR: Target[10.78.2.80_10][_OUT_] ' $target->[909]{$mode} ' did not eval into defined data
2017-12-29 09:30:24: ERROR: Target[10.78.2.80_11][_IN_] ' $target->[910]{$mode} ' did not eval into defined data
2017-12-29 09:30:24: ERROR: Target[10.78.2.80_11][_OUT_] ' $target->[910]{$mode} ' did not eval into defined data
2017-12-29 09:30:24: ERROR: Target[10.78.2.80_12][_IN_] ' $target->[911]{$mode} ' did not eval into defined data
2017-12-29 09:30:24: ERROR: Target[10.78.2.80_12][_OUT_] ' $target->[911]{$mode} ' did not eval into defined data
2017-12-29 09:30:24: ERROR: Target[10.78.2.80_13][_IN_] ' $target->[912]{$mode} ' did not eval into defined data
2017-12-29 09:30:24: ERROR: Target[10.78.2.80_13][_OUT_] ' $target->[912]{$mode} ' did not eval into defined data
2017-12-29 09:30:24: ERROR: Target[10.78.2.80_14][_IN_] ' $target->[913]{$mode} ' did not eval into defined data
2017-12-29 09:30:24: ERROR: Target[10.78.2.80_14][_OUT_] ' $target->[913]{$mode} ' did not eval into defined data
2017-12-29 09:30:24: ERROR: Target[10.78.2.80_15][_IN_] ' $target->[914]{$mode} ' did not eval into defined data
2017-12-29 09:30:24: ERROR: Target[10.78.2.80_15][_OUT_] ' $target->[914]{$mode} ' did not eval into defined data
2017-12-29 09:30:24: ERROR: Target[10.78.2.80_16][_IN_] ' $target->[915]{$mode} ' did not eval into defined data
2017-12-29 09:30:24: ERROR: Target[10.78.2.80_16][_OUT_] ' $target->[915]{$mode} ' did not eval into defined data
2017-12-29 09:30:24: ERROR: Target[10.78.2.80_17][_IN_] ' $target->[916]{$mode} ' did not eval into defined data
2017-12-29 09:30:24: ERROR: Target[10.78.2.80_17][_OUT_] ' $target->[916]{$mode} ' did not eval into defined data
2017-12-29 09:30:24: ERROR: Target[10.78.2.80_18][_IN_] ' $target->[917]{$mode} ' did not eval into defined data
2017-12-29 09:30:24: ERROR: Target[10.78.2.80_18][_OUT_] ' $target->[917]{$mode} ' did not eval into defined data
2017-12-29 09:30:24: ERROR: Target[10.78.2.80_19][_IN_] ' $target->[918]{$mode} ' did not eval into defined data
2017-12-29 09:30:24: ERROR: Target[10.78.2.80_19][_OUT_] ' $target->[918]{$mode} ' did not eval into defined data
2017-12-29 09:30:24: ERROR: Target[10.78.2.80_20][_IN_] ' $target->[919]{$mode} ' did not eval into defined data
2017-12-29 09:30:24: ERROR: Target[10.78.2.80_20][_OUT_] ' $target->[919]{$mode} ' did not eval into defined data
2017-12-29 09:30:24: ERROR: Target[10.78.2.80_21][_IN_] ' $target->[920]{$mode} ' did not eval into defined data
2017-12-29 09:30:24: ERROR: Target[10.78.2.80_21][_OUT_] ' $target->[920]{$mode} ' did not eval into defined data
2017-12-29 09:30:24: ERROR: Target[10.78.2.80_22][_IN_] ' $target->[921]{$mode} ' did not eval into defined data
2017-12-29 09:30:24: ERROR: Target[10.78.2.80_22][_OUT_] ' $target->[921]{$mode} ' did not eval into defined data
2017-12-29 09:30:24: ERROR: Target[10.78.2.80_23][_IN_] ' $target->[922]{$mode} ' did not eval into defined data
2017-12-29 09:30:24: ERROR: Target[10.78.2.80_23][_OUT_] ' $target->[922]{$mode} ' did not eval into defined data
2017-12-29 09:30:24: ERROR: Target[10.78.2.80_24][_IN_] ' $target->[923]{$mode} ' did not eval into defined data
2017-12-29 09:30:24: ERROR: Target[10.78.2.80_24][_OUT_] ' $target->[923]{$mode} ' did not eval into defined data
2017-12-29 09:30:24: ERROR: Target[10.78.2.80_25][_IN_] ' $target->[924]{$mode} ' did not eval into defined data
2017-12-29 09:30:24: ERROR: Target[10.78.2.80_25][_OUT_] ' $target->[924]{$mode} ' did not eval into defined data
2017-12-29 09:30:24: ERROR: Target[10.78.2.80_26][_IN_] ' $target->[925]{$mode} ' did not eval into defined data
2017-12-29 09:30:24: ERROR: Target[10.78.2.80_26][_OUT_] ' $target->[925]{$mode} ' did not eval into defined data
2017-12-29 09:30:24: ERROR: Target[10.78.2.80_27][_IN_] ' $target->[926]{$mode} ' did not eval into defined data
2017-12-29 09:30:24: ERROR: Target[10.78.2.80_27][_OUT_] ' $target->[926]{$mode} ' did not eval into defined data
2017-12-29 09:30:24: ERROR: Target[10.78.2.80_28][_IN_] ' $target->[927]{$mode} ' did not eval into defined data
2017-12-29 09:30:24: ERROR: Target[10.78.2.80_28][_OUT_] ' $target->[927]{$mode} ' did not eval into defined data
2017-12-29 09:30:24: ERROR: Target[10.78.2.80_29][_IN_] ' $target->[928]{$mode} ' did not eval into defined data
2017-12-29 09:30:24: ERROR: Target[10.78.2.80_29][_OUT_] ' $target->[928]{$mode} ' did not eval into defined data
2017-12-29 09:30:24: ERROR: Target[10.78.2.80_30][_IN_] ' $target->[929]{$mode} ' did not eval into defined data
2017-12-29 09:30:24: ERROR: Target[10.78.2.80_30][_OUT_] ' $target->[929]{$mode} ' did not eval into defined data
2017-12-29 09:30:24: ERROR: Target[10.78.2.80_31][_IN_] ' $target->[930]{$mode} ' did not eval into defined data
2017-12-29 09:30:24: ERROR: Target[10.78.2.80_31][_OUT_] ' $target->[930]{$mode} ' did not eval into defined data
2017-12-29 09:30:24: ERROR: Target[10.78.2.80_32][_IN_] ' $target->[931]{$mode} ' did not eval into defined data
2017-12-29 09:30:24: ERROR: Target[10.78.2.80_32][_OUT_] ' $target->[931]{$mode} ' did not eval into defined data
2017-12-29 09:30:24: ERROR: Target[10.78.2.80_33][_IN_] ' $target->[932]{$mode} ' did not eval into defined data
2017-12-29 09:30:24: ERROR: Target[10.78.2.80_33][_OUT_] ' $target->[932]{$mode} ' did not eval into defined data
2017-12-29 09:30:24: ERROR: Target[10.78.2.80_34][_IN_] ' $target->[933]{$mode} ' did not eval into defined data
2017-12-29 09:30:24: ERROR: Target[10.78.2.80_34][_OUT_] ' $target->[933]{$mode} ' did not eval into defined data
2017-12-29 09:30:24: ERROR: Target[10.78.2.80_35][_IN_] ' $target->[934]{$mode} ' did not eval into defined data
2017-12-29 09:30:24: ERROR: Target[10.78.2.80_35][_OUT_] ' $target->[934]{$mode} ' did not eval into defined data
2017-12-29 09:30:24: ERROR: Target[10.78.2.80_36][_IN_] ' $target->[935]{$mode} ' did not eval into defined data
2017-12-29 09:30:24: ERROR: Target[10.78.2.80_36][_OUT_] ' $target->[935]{$mode} ' did not eval into defined data
2017-12-29 09:30:24: ERROR: Target[10.78.2.80_37][_IN_] ' $target->[936]{$mode} ' did not eval into defined data
2017-12-29 09:30:24: ERROR: Target[10.78.2.80_37][_OUT_] ' $target->[936]{$mode} ' did not eval into defined data
2017-12-29 09:30:24: ERROR: Target[10.78.2.80_38][_IN_] ' $target->[937]{$mode} ' did not eval into defined data
2017-12-29 09:30:24: ERROR: Target[10.78.2.80_38][_OUT_] ' $target->[937]{$mode} ' did not eval into defined data
2017-12-29 09:30:24: ERROR: Target[10.78.2.80_39][_IN_] ' $target->[938]{$mode} ' did not eval into defined data
2017-12-29 09:30:24: ERROR: Target[10.78.2.80_39][_OUT_] ' $target->[938]{$mode} ' did not eval into defined data
2017-12-29 09:30:24: ERROR: Target[10.78.2.80_40][_IN_] ' $target->[939]{$mode} ' did not eval into defined data
2017-12-29 09:30:24: ERROR: Target[10.78.2.80_40][_OUT_] ' $target->[939]{$mode} ' did not eval into defined data
2017-12-29 09:30:24: ERROR: Target[10.78.2.80_41][_IN_] ' $target->[940]{$mode} ' did not eval into defined data
2017-12-29 09:30:24: ERROR: Target[10.78.2.80_41][_OUT_] ' $target->[940]{$mode} ' did not eval into defined data
2017-12-29 09:30:24: ERROR: Target[10.78.2.80_42][_IN_] ' $target->[941]{$mode} ' did not eval into defined data
2017-12-29 09:30:24: ERROR: Target[10.78.2.80_42][_OUT_] ' $target->[941]{$mode} ' did not eval into defined data
2017-12-29 09:30:24: ERROR: Target[10.78.2.80_43][_IN_] ' $target->[942]{$mode} ' did not eval into defined data
2017-12-29 09:30:24: ERROR: Target[10.78.2.80_43][_OUT_] ' $target->[942]{$mode} ' did not eval into defined data
2017-12-29 09:30:24: ERROR: Target[10.78.2.80_44][_IN_] ' $target->[943]{$mode} ' did not eval into defined data
2017-12-29 09:30:24: ERROR: Target[10.78.2.80_44][_OUT_] ' $target->[943]{$mode} ' did not eval into defined data
2017-12-29 09:30:24: ERROR: Target[10.78.2.80_45][_IN_] ' $target->[944]{$mode} ' did not eval into defined data
2017-12-29 09:30:24: ERROR: Target[10.78.2.80_45][_OUT_] ' $target->[944]{$mode} ' did not eval into defined data
2017-12-29 09:30:24: ERROR: Target[10.78.2.80_46][_IN_] ' $target->[945]{$mode} ' did not eval into defined data
2017-12-29 09:30:24: ERROR: Target[10.78.2.80_46][_OUT_] ' $target->[945]{$mode} ' did not eval into defined data
2017-12-29 09:30:24: ERROR: Target[10.78.2.80_47][_IN_] ' $target->[946]{$mode} ' did not eval into defined data
2017-12-29 09:30:24: ERROR: Target[10.78.2.80_47][_OUT_] ' $target->[946]{$mode} ' did not eval into defined data
2017-12-29 09:30:24: ERROR: Target[10.78.2.80_48][_IN_] ' $target->[947]{$mode} ' did not eval into defined data
2017-12-29 09:30:24: ERROR: Target[10.78.2.80_48][_OUT_] ' $target->[947]{$mode} ' did not eval into defined data
2017-12-29 09:30:24: ERROR: Target[10.78.2.80_417][_IN_] ' $target->[948]{$mode} ' did not eval into defined data
2017-12-29 09:30:24: ERROR: Target[10.78.2.80_417][_OUT_] ' $target->[948]{$mode} ' did not eval into defined data
2017-12-29 09:30:24: ERROR: Target[10.78.2.80_418][_IN_] ' $target->[949]{$mode} ' did not eval into defined data
2017-12-29 09:30:24: ERROR: Target[10.78.2.80_418][_OUT_] ' $target->[949]{$mode} ' did not eval into defined data
2017-12-29 09:30:24: ERROR: Target[10.78.2.80_419][_IN_] ' $target->[950]{$mode} ' did not eval into defined data
2017-12-29 09:30:24: ERROR: Target[10.78.2.80_419][_OUT_] ' $target->[950]{$mode} ' did not eval into defined data
2017-12-29 09:30:24: ERROR: Target[10.78.2.80_420][_IN_] ' $target->[951]{$mode} ' did not eval into defined data
2017-12-29 09:30:24: ERROR: Target[10.78.2.80_420][_OUT_] ' $target->[951]{$mode} ' did not eval into defined data
2017-12-29 09:30:24: ERROR: Target[10.78.2.80_421][_IN_] ' $target->[952]{$mode} ' did not eval into defined data
2017-12-29 09:30:24: ERROR: Target[10.78.2.80_421][_OUT_] ' $target->[952]{$mode} ' did not eval into defined data
2017-12-29 09:30:24: ERROR: Target[10.78.2.80_422][_IN_] ' $target->[953]{$mode} ' did not eval into defined data
2017-12-29 09:30:24: ERROR: Target[10.78.2.80_422][_OUT_] ' $target->[953]{$mode} ' did not eval into defined data
2017-12-29 09:30:24: ERROR: Target[10.78.2.80_423][_IN_] ' $target->[954]{$mode} ' did not eval into defined data
2017-12-29 09:30:24: ERROR: Target[10.78.2.80_423][_OUT_] ' $target->[954]{$mode} ' did not eval into defined data
Am I safe to kill the process on the server? How do I fix this?
Re: MRTG and Net_SNMP_util.pm file looks for nonexisting hos
Post by dwhitfield »
Where are you seeing this? You may be able to get rid of those messages by stopping the crontab from sending these by changing the following in /etc/cron.d/mrtg
change this
    */5 * * * * root LANG=C LC_ALL=C /usr/bin/mrtg /etc/mrtg/mrtg.cfg --lock-file /var/lock/mrtg/mrtg_l --confcache-file /var/lib/mrtg/mrtg.ok
to this
    */5 * * * * root LANG=C LC_ALL=C /usr/bin/mrtg /etc/mrtg/mrtg.cfg --lock-file /var/lock/mrtg/mrtg_l --confcache-file /var/lib/mrtg/mrtg.ok 2>&1
Additionally, can you PM me your Profile? You can download it by going to Admin > System Config > System Profile and click the ***Download Profile*** button towards the top. If for whatever reason you *cannot* download the profile, please put the output of View System Info (5.3.4+, Show Profile if older) in the thread (that will at least get us some info). This will give us access to many of the logs we would otherwise ask for individually. If security is a concern, you can unzip the profile take out what you like, and then zip it up again. We may end up needing something you remove, but we can ask for that specifically.
You can also generate a profile manually using the script at /usr/local/nagiosxi/html/includes/components/profile/getprofile.sh
That should generate a profile in /usr/local/nagiosxi/var/components/ which you can get off the server with an application such as FileZilla.
If you get an error that PROFILE BUILD FAILED, please see https://support.nagios.com/kb/article.p ... ategory=44
sathevaner
Thank you, @dwhitfield. Changing the mrtg cron.d script did not stop the messages.
I have pasted a redacted version of the System Info before from clicking "View".
Nagios XI - System Info
System:
Nagios XI Version : 5.4.11
2.6.32-696.16.1.el6.x86_64 x86_64
Red Hat Enterprise Linux Server release 6.9 (Santiago)
Gnome Installed
Apache Information
PHP Version: 5.3.3
Server Port: 80
Date/Time
PHP Timezone: America/Chicago
PHP Time: Fri, 29 Dec 2017 10:58:42 -0600
System Time: Fri, 29 Dec 2017 10:58:42 -0600
Nagios XI Data
License ends in: PQQNTT
nagios (pid 18299) is running...
NPCD running (pid 10737).
ndo2db (pid 10629) is running...
CPU Load 15: 0.20
Total Hosts: 13
Total Services: 1840
Function 'get_base_uri' returns: http://[IP]/nagiosxi/
Function 'get_base_url' returns: http://[IP]/nagiosxi/
Function 'get_backend_url(internal_call=false)' returns: http://[IP]/nagiosxi/includes/components/profile/profile.php
Function 'get_backend_url(internal_call=true)' returns: http://localhost/nagiosxi/backend/
Ping Test localhost
Running:
/bin/ping -c 3 localhost 2>&1
PING localhost (127.0.0.1) 56(84) bytes of data.
64 bytes from localhost (127.0.0.1): icmp_seq=1 ttl=64 time=0.025 ms
64 bytes from localhost (127.0.0.1): icmp_seq=2 ttl=64 time=0.019 ms
64 bytes from localhost (127.0.0.1): icmp_seq=3 ttl=64 time=0.016 ms
--- localhost ping statistics ---
3 packets transmitted, 3 received, 0% packet loss, time 2000ms
rtt min/avg/max/mdev = 0.016/0.020/0.025/0.003 ms
Test wget To localhost
WGET From URL: http://localhost/nagiosxi/includes/components/ccm/
Running:
/usr/bin/wget http://localhost/nagiosxi/includes/components/ccm/
--2017-12-29 10:58:44-- http://localhost/nagiosxi/includes/components/ccm/
Resolving localhost... ::1, 127.0.0.1
Connecting to localhost|::1|:80... connected.
HTTP request sent, awaiting response... 302 Found
Location: http://localhost/nagiosxi/login.php?redirect=/nagiosxi/includes/components/ccm/index.php%3f&noauth=1 [following]
--2017-12-29 10:58:44-- http://localhost/nagiosxi/login.php?redirect=/nagiosxi/includes/components/ccm/index.php%3f&noauth=1
Length: unspecified [text/html]
Saving to: "/usr/local/nagiosxi/tmp/ccm_index.tmp"
0K .......... .......... ..... 2.40M=0.01s
2017-12-29 10:58:44 (2.40 MB/s) - "/usr/local/nagiosxi/tmp/ccm_index.tmp" saved [26012]
If you need to see more information, then I'll be happy to privately provide it. I'd prefer to avoid sharing IP addresses, hostnames, MAC addresses, and others like this if I can avoid it.
Where are you seeing those errors? Is it in a log file? Can you send that entire log file?
When you say "started running this morning" do you mean that you ran a mrtg script manually? Is there a reason you did this? What is the command that you ran?
If you are concerned about sending the profile on the forum, I would suggest submitting a ticket at https://support.nagios.com/tickets/
It's not impossible to figure this out without a profile, but it does make things much more difficult, collecting the logs individually.
sathevaner
dwhitfield wrote:Where are you seeing those errors? Is it in a log file? Can you send that entire log file?
That was pasted directly from e-mail notifications, as the result of Cron.
dwhitfield wrote:When you say "started running this morning" do you mean that you ran a mrtg script manually? Is there a reason you did this? What is the command that you ran?
It run as the result of the script being in the cron.d directory. I was working with a few test hosts that got removed last night. For some reason, the system thinks they're still there.
What is causing those errors is a left over MRTG configuration file and it has to be removed so it will stop generating the errors.
Go to this folder
/etc/mrtg/conf.d
Delete the file with the IP address of the device that was removed from your network.
From your previous post, the name of the files should be
10.78.2.81.cfg
10.78.2.80.cfg
Then restart the cron daemon by running the following as root
service crond restart
The next time cron runs the mrtg job, it should not generate those errors and stop the emails from being sent.
sathevaner
Thank you, @tgriep, that was the problem. It is now resolved on our server.
Do you know what caused these leftover .cfg files to remain in this directory? I've never encountered this with any other host I've deleted.
The way the MRTG config files work has undergone some changes. We can give you more details on this if you like, but suffice it to say I suspect your different hosts were created with different versions of the Network Router/Switch Wizard. Does that seem likely? What version of the Router/Switch Wizard are you using now?
sathevaner
dwhitfield wrote:The way the MRTG config files work has undergone some changes. We can give you more details on this if you like, but suffice it to say I suspect your different hosts were created with different versions of the Network Router/Switch Wizard. Does that seem likely? What version of the Router/Switch Wizard are you using now?
I don't think so. This is a fairly fresh installation of Nagios XI. We're still using the 1.0.3 version of that wizard.
That sounds like you aren't using the Router/Switch Wizard but rather the Generic Network Device Wizard. This could be the source of your different outcomes (some from one wizard, some from another).
For clarity, the actual issue is resolved, correct?
