Dear Expert
In Nagvis map, adding Service Status so it will show Green/Red line according to link Up/Down, its Okay here. However the same Host+Link having multiple similar services, we want to display the same when we hover it.
Router1 , Giga 0/1 Status (OK: Interface ge-0/1 (index 572) is up.)
Router1 , Giga 0/1 Bandwidth (OK Current BW in: 1.7Mbps out: 3.5Mbps)
Router1 , Giga 0/1 Latency (OK Current rtt: 53ms)
As we adding Status, its showing UP (green) and when we hover it on the rectangular box, showing more info about the Status , Alias, Display_Name, etc.....here we want to display Current Bandwidth and Current Latency. How?
We tried to take help from Nagvis documention but no success, need your expertization.
Regards
multiple service output in Nagvis hover menu
- Former Nagios Staff
Re: multiple service output in Nagvis hover menu
I think the answer you seek can be found at https://support.nagios.com/forum/viewto ... =7&t=37332
I'm not exactly sure if that template is going to get you what you want, which is why I am giving you the entire thread for context. Basically, I think you're looking for a file like /usr/local/nagvis/share/userfiles/templates/default-pnp.hover.html but pay attention to the other files in that directory and make sure you take a backup before changing anything.
