We just purchased and deployed XI, it looks like only the default local admin is setup to alert under each service/host. If i go in and add the admin contact group to a host everyone starts getting alerts as we would hope.
But how can I add the group to All Hosts and Services? Can I just change the templates or is there a better way? If I update the alert settings on the template will it automatically update all hosts and services that use it?
Add All Admins to Alerts
kyang
Re: Add All Admins to Alerts
If you have an enterprise licensed XI or trial in for it in use, you can do so using the Bulk Modifications Tools.
In the Core Config Manager --> under Tools (click Bulk Modifications Tool) --> click "Add contact group" Select the Hosts/services you want or left-click and drag to add all hosts/services for each window.
