[Error] Logstash sending logs to Kafka
carlos.mangini
Post by carlos.mangini »
I need to send logs from my logstash to kafka. After install via plugin "logstash-output-kafka", when I config de logstash.conf output, I'm getting this error:
./logstash --configtest -f /usr/local/nagioslogserver/logstash/etc/conf.d/999_outputs.conf
Unknown setting 'bootstrap_servers' for kafka {:level=>:error}
#999_outputs.conf
kafka {
topic_id => "logstash-kafka"
bootstrap_server => "200.185.10.10:2181"
I tried use others sintax for testing, like (acks, retries) but got the same error.
Could you guys give me some light?
My kafka server is not the same virtual machine. I don´t have problems with network or firewall.
Re: [Error] Logstash sending logs to Kafka
Post by mcapra »
If you're using a NLS version < 2.0.0, you'll want to reference the documentation for the Logstash 1.5 version of the plugin:
https://www.elastic.co/guide/en/logstas ... kafka.html
If you're using a NLS version > 2.0.0, you'll want to reference the documentation for the Logstash 2.4 version of the plugin:
I'm guessing your NLS version is < 2.0.0, meaning you'll want to use the broker_list directive instead of bootstrap_server. Let me know if I'm wrong.
cdienger
Post by cdienger »
Thanks for the info,@mcapra. Has this helped resolve your issue, @carlos.mangini?
carlos.mangini
Yes @cdienger! ;)
Thank you @mcapra!!
It was exactly what I needed, solving my problem. :D
kyang
Post by kyang »
Sounds good! Did you have any more questions or are we okay to lock this up?
carlos.mangini
No. Thank you guys!
