Import old data to new XI?
dimsum
Post by dimsum »
Hi Guys,
I have a problem to move all old data to new XI. Is it possible in a simple export/import? So I have 2 XI run on the same version.
Please advise,
Thank you.
bolson
Re: Import old data to new XI?
Post by bolson »
Which version are you migrating from?
dimsum
Post by dimsum »
Is Nagios XI 5.4.11 to Nagios XI 5.4.11
Thank you.
bolson
Post by bolson »
Simply backup your Nagios XI on the existing XI installation and restore to the new installation. Here's how:
dimsum
Post by dimsum »
Thank for the link.
I try restore from backup the information it's okay but I can't see the performance graph with the old data ~1,000 hosts. Alternatively, I was backed up and restore another XI it's worked all information Nagios XI but this XI is ~100 hosts. see the difference XI picture.
Could you advise?
Thanks.
npolovenko
Post by npolovenko »
@dimsum, Did you happen to migrate from a 32bit system to a 64bit one? If so, please take a look at this tutorial:
https://support.nagios.com/kb/article.php?id=166
Otherwise, could you send in your Nagios XI System Profile so I can review it?
To send us your system profile. Login to the Nagios XI GUI using a web browser.
Save the profile.zip file and attach it to your next post, or you can upload it to a cloud storage of your choice and share a link with me in pm.
npolovenko
@dimsum, I received your profile and shared it with the support team. Seems like you may have some permission problems. Please navigate to:
 /usr/local/nagiosxi/scripts/
and run the script:
./reset_config_perms.sh
Let us know if that fixed your problem. Please allow XI to run for at least 10-15 minutes after you run this script before checking on it.
dimsum
Post by dimsum »
[root@nagiso-restore scripts]# ./reset_config_perms.sh
RESETTING PERMS
/bin/chmod: cannot access ‘/usr/local/nagios/share/perfdata/’: No such file or directory
/bin/find: ‘/usr/local/nagios/share/perfdata/’: No such file or directory
Perhaps the folder is missing! Can I download from the old XI? When I run the backup on web UI isn't back up a perfdata?
Thanks.
npolovenko
@dimsum, I think that folder should've been transferred over during the backup. Can you manually navigate to /usr/local/nagios/share/ and make sure that there's no perfdata folder? If there isn't you may copy it from the old XI server. After you copy it please run the following commands and show us the output:
service nagios restart
service npcd status
service crond status
dimsum
Post by dimsum »
The problem has been fixed. It's a problem with the link directory mismatch. because from the old XI has changed a perfdata path to /home.
Thanks guys for helping.
