Hi guys. I installed Nsclient++ on Windows NT4. We have tons of them alive, believe or not.
Could you please tell me how to consult disk information from a Centos 6 box?
Is there a simple way to check this without installing nagios?
A standalone command (check_nt) or something?
Thank you!
NSclient++ 0.3 - disk information
npolovenko
- Support Tech
Re: NSclient++ 0.3 - disk information
@gera83, You could just compile the check_nt plugin without installing Nagios:
https://support.nagios.com/kb/article.php?id=569
And then pass the command to the plugin manually:
Something like this. Although, the exact syntax could differ as you're running a very old version of NSClient.
./check_nt -H remote_ip -p 12345 -v USEDDISKSPACE -d SHOWALL -l c -t 60As of May 25th, 2018, all communications with Nagios Enterprises and its employees are covered under our new Privacy Policy.
