I need help getting the regex on disk usage to show op on nagiographer. Here is my output. Im new at this, and need some direction.
2018-01-04 14:13:53 PIPE: comsup2 Disk Space DISK OK /=4439774MB;7442596;7442696;0;7442796 /dev=0MB;63029;63672;0;64316 /dev/shm=0MB;63040;63683;0;64327 /run=4077MB;63040;63683;0;64327 /sys/fs/cgroup=0MB;63040;63683;0;64327 /boot=157MB;506;511;0;517 /boot/efi=9MB;279;282;0;285 /tmp=43MB;20547;20757;0;20967 /var=1713MB;20547;20757;0;20967 /var/log=1890MB;20547;20757;0;20967 /var/tmp=33091MB;42035;42464;0;42893 /home=18408MB;20547;20757;0;20967 /var/log/audit=71MB;20547;20757;0;20967 1515104010
2018-01-04 14:13:53 VALUES: [comsup2][Disk Space]:No matching output values found...
NagiosGrapher disk usage
kyang
Re: NagiosGrapher disk usage
Which plugin are you using to get this output? check_disk?
Any screenshots? That would help a lot, so I know what the error is on nagiosgrapher.
Also, please note that nagiosgrapher was developed by a third-party and not us.
Thanks!
Is this showing on the interface or where?2018-01-04 14:13:53 VALUES: [comsup2][Disk Space]:No matching output values found...
Thanks!
