Post Upgrade Issues
hoegh
Post Upgrade Issues
Post by hoegh »
We have upgraded our Nagios xi to 5.4.11.
The upgrade was successful but we are getting the below error for Oracle servers :
install_driver(Oracle) failed: Can't load '/usr/local/lib64/perl5/auto/DBD/Oracle/Oracle.so' for module DBD::Oracle: libclntsh.so.1
Kindly provide steps to rectify this error.
We have this script check_oracle_health-1.7.3 on Nagios server.
Do we have to run this script.
Kindly assist.
Thanks & Regards,
Neha Singh.
Höegh
Re: Post Upgrade Issues
Post by dwhitfield »
What version of Oracle are you checking? You may need to change the command from 12 to 11. https://assets.nagios.com/downloads/nag ... ios-XI.pdf should be of use.
hoegh
Post by hoegh »
We have changed the parameters.
Thanks.
Regards,
Neha Singh.
Höegh
kyang
Post by kyang »
Sounds good, did that fix the issue or not?
Let us know if you have any more questions or if we are okay to lock this up? Thanks
hoegh
Post by hoegh »
Hi ,
Yes the issue is fixed now.
We can close it now.
Thanks & Regards,
Neha Singh.
