Moderator Edit: This thread has been split from another - https://support.nagios.com/forum/viewto ... =6&t=44991
In the future, please create a new thread and link to the old one instead of adding on.
Hello Nagios Support,
We are also facing same issues, The exported csv report timestamp are not in human readable format.
If possible, could you pl share the options in Nagios XI where we can export this in csv OR excel format.
Nagios Report CSV
npolovenko
- Support Tech
Re: Nagios Report CSV
Hello, @ganesh.batwal. Aside from the solutions suggested in the original thread, I could add one more. You could download a regular CSV and then convert epoch timestamps to a readable format using excel formula:
https://www.extendoffice.com/documents/ ... -date.html
