Hello:
As per the Subject, and as per similar issues I noted from this post and a few other Google hits:
https://support.nagios.com/forum/viewto ... =6&t=34289
Our repolist (repolist.jpg attached) identifies the needed repositories and the Oracle Enterprise Linux optional channel is enabled, too.
Since we do not run Red Hat nor CentOS, specifically, It appears that the Oracle Enterprise Linux optional channel may not have the needed dependencies or latest packages required, so, am looking for assistance with where should I grab the needed files/rpms/etc.?
Error installing Nagios XI 5.4.11 on OEL 7.3 (Oracle Ent)
Newbie '14
Re: Error installing Nagios XI 5.4.11 on OEL 7.3 (Oracle Ent
As a side note, I laughed at line 94 in "0-repos".
Newbie '14
I checked the Nagios XI scripts and noted that it wanted "public-yum-ol7.repo" so I have disabled our internal yum repo and enabled the public repo, then tried the full install again.
Still failed.
Posting snapshot and looking for assistance.
Thank you.
Still failed.
Thank you.
Newbie '14
Oracle Enterprise Linux is NOT supported... at least, not yet.
Having said that, Nagios XI 5.4.11 installed just fine on one of my test VMs, running "stock" Oracle Linux Server 7.4.
https://assets.nagios.com/downloads/nag ... -Linux.pdfAs of the time of writing, Nagios Enterprises is only able to officially provide support for installing Nagios XI on
the following Linux Distributions:
• RHEL 6.x 32-bit and 64-bit, RHEL 7.x
• CentOS 6.x 32-bit and 64-bit, CentOS 7.x
Nagios XI Installation Complete!
You can access the Nagios XI web interface by visiting:
http://192.168.4.45/nagiosxi/Code: Select all
[root@localhost nagiosxi]# uname -a
Linux localhost.localdomain 4.1.12-112.14.10.el7uek.x86_64 #2 SMP Mon Jan 8 18:26:37 PST 2018 x86_64 x86_64 x86_64 GNU/LinuxCode: Select all
[root@localhost nagiosxi]# cat /etc/*release
Oracle Linux Server release 7.4
NAME="Oracle Linux Server"
VERSION="7.4"
ID="ol"
VERSION_ID="7.4"
PRETTY_NAME="Oracle Linux Server 7.4"
ANSI_COLOR="0;31"
CPE_NAME="cpe:/o:oracle:linux:7:4:server"
HOME_URL="https://linux.oracle.com/"
BUG_REPORT_URL="https://bugzilla.oracle.com/"
ORACLE_BUGZILLA_PRODUCT="Oracle Linux 7"
ORACLE_BUGZILLA_PRODUCT_VERSION=7.4
ORACLE_SUPPORT_PRODUCT="Oracle Linux"
ORACLE_SUPPORT_PRODUCT_VERSION=7.4
Red Hat Enterprise Linux Server release 7.4 (Maipo)
Oracle Linux Server release 7.4Code: Select all
[root@localhost nagiosxi]# yum repolist
Loaded plugins: ulninfo
repo id repo name status
*epel/x86_64 Extra Packages for Enterprise Linux 7 - x86_64 12,198
nagios-base Nagios 81
nagiosxi-deps Nagios XI Dependencies 26
ol7_UEKR4/x86_64 Latest Unbreakable Enterprise Kernel Release 4 for Oracle Linux 7Server (x86_64) 537
ol7_latest/x86_64 Oracle Linux 7Server Latest (x86_64) 23,669
ol7_optional_latest/x86_64 Oracle Linux 7Server Optional Latest (x86_64) 16,672
repolist: 53,183Be sure to check out our Knowledgebase for helpful articles and solutions!
*Soapbox* - Oracle Enterprise Linux "IS" another CentOS system, it just doesn't have Red Hat's marketing and handful of files with their trademark strewn across the file structure, so it doesn't matter. Plus, the NagiosXI installer accommodates Oracle in the scripts. No biggie. *stepping down off soapbox*
I have disabled the Webtatic and "remi" epos, removed all php components, phpmyadmin components, mysql components, etc., restarted the server, double-checked things, and reran the NagiosXI full install. This time the error occurs regarding 4 components that are supposedly with "nagiosxi-deps-el7-5.4.11-1.noarch" (attachment provided).
This should work, and WILL work, if someone can propose a solution for those last 4 parts: perl-Math-Calc-Units, python-pip, libmcrypt-devel, and freetds-devel (unless they are not needed and there is a work-around).
Thank you!
Thank you!
Newbie '14
Solved: Enabled the "epel.repo" repo and tried again. Installation is working.
Newbie '14
npolovenko
- Support Tech
@PhilG Thanks for your input! Did you get everything to work? Should I go ahead and lock the thread or do you have some other questions?
npolovenko wrote:@PhilG Thanks for your input! Did you get everything to work? Should I go ahead and lock the thread or do you have some other questions?
Yes. I will provide some background for your team to help you out, too:
I had created an Oracle Enterprise Linux 7.3 Web Apache server VM template in our vShere environment which contained phpMyAdmin and a couple of other "canned" items which used the "Webtatic" repo and a couple of other repos to accommodate the additional packages that were installed before creating the VM template. Additionally, we have an internal YUM repository server which goes out to Oracle, so we use a custom internal YUM repo, too.
SOLUTION: As one of your team members mentioned/suggested in a response (and is noted in the Nagios XI Linux installation notes, too), I should use a "BASE" OS install, which wouldn't contain any "extras" or special repos. In my case, if I wanted to use our VM, I had to rip out the "extras" noted above (phpMyAdmin, repos, etc.), and re-enable Oracle's public community repo and the "epel" repo. After manually removing the "extras" and re-enabling the needed repos, the Nagios XI installation worked with no issues thereafter.
I am now starting to configure the new Nagios XI server and web console. Things I will need to configure:
1). Redirect HTTP to HTTPS
2). Customize/configure everyone's Home Dashboard with the same view.
3). Migrate existing Nagios XI server/environment into the new Nagios XI server/environment (create a new SCCM NSClient++ package and push out to the Windows servers. Figure out Puppet to push update/change to Linux servers): this includes all host groups, service groups, accounts, etc. etc.
I'll look for a solution regarding server migration in the forum or Knowledgebase first.
You may lock this thread.
Thank you.
Newbie '14
