NRPE Not Returning Value
danielgaraventa_ats
Post by danielgaraventa_ats »
We have a custom check that we have written for our Oracle database servers to check the number of days left until passwords expire via an SQL command. We are currently testing on moving our databases to RHEL 7 from SUSE 11. Running on SUSE 11 the check works as expected when we run the script through NRPE. On RHEL 7 the output from the SQL command does not seem to be being passed to NRPE It does work fine however when I run the check locally on the RHEL 7 server.
#!/bin/bash
# Nagios return codes
UNKNOWN=3
CRIT=2
WARN=1
OK=0
OUT=$(/opt/oracle/product/11.2.0.4/bin/sqlplus -S redacted/redacted@svr-rhel7/SID << EOF
set head off;
select nvl( min(trunc(expiry_date) - trunc(sysdate)),90) days_remaining from dba_users u where expiry_date is not null and account_status = 'OPEN';
exit
EOF
export OUT
if test "$OUT" -gt 30; then
  echo "OK - Passwords are not set to expire for another "$OUT" days"
  exit $OK
elif test "$OUT" -gt 14; then
  echo "WARN - Passwords are scheduled to expire in "$OUT" days"
  exit $WARN
else
  echo "CRIT - Passwords are scheduled to expire in "$OUT" days"
  exit $CRIT
fi
When I run the script locally on the RHEL 7 box I get the following output.
[root@svr-rhel7 plugins]# runuser -u nrpe /usr/lib64/nagios/plugins/test2
OK - Passwords are not set to expire for another  90 days
When I run the check_nrpe on our Nagios XI server I see the following output.
[root@monitor libexec]# ./check_nrpe -H svr-rhel7 -t 60 -p 5666 -4 -c test2
CRIT - Passwords are scheduled to expire in  days
We are currently running Nagios XI 5.4.11 and I have also disabled SELinux on the RHEL 7 server.
Thank you for any advice,
Daniel
Last edited by danielgaraventa_ats on Thu Jan 11, 2018 12:37 pm, edited 1 time in total.
npolovenko
Re: NRPE Not Returning Value
Post by npolovenko »
Hello, @danielgaraventa_ats.
What're the permissions on this folder?
When you run it locally it runs as a sudo user but if you run it with Nagios it runs as a Nagios user.
I'd probably do chmod +x on that folder to see if that resolves the problem.
danielgaraventa_ats
Hello npolovenko,
sqlplus is a file in /opt/oracle/product/11.2.0.4/bin which has the following permissions.
[root@ats-db-04 ~]# ls -la /opt/oracle/product/11.2.0.4/bin/sqlplus
-rwxr-x--x. 1 oracle oinstall 13575 Jun 24  2014 /opt/oracle/product/11.2.0.4/bin/sqlplus
/opt/oracle/product/11.2.0.4/bin has the following permissions set.
[root@ats-db-04 ~]# ls -lad /opt/oracle/product/11.2.0.4/bin/
drwxr-xr-x. 2 oracle oinstall 12288 Nov 30 08:56 /opt/oracle/product/11.2.0.4/bin/
I have added the nagios and the nrpe user to the oinstall group.
[root@ats-db-04 ~]# groups nrpe
nrpe : nrpe oinstall nagios
[root@ats-db-04 ~]# groups nagios
nagios : nagios oinstall
I still seem to get the same results sadly.
Daniel
npolovenko
@danielgaraventa_ats, On the remote server, can you change the username to Nagios:
su - nagios
And then attempt to run the script locally. Does it work?
Are you running nrpe as a standalone service or under xinetd daemon?
danielgaraventa_ats
If I su to the nagios user locally the script runs normally.
[nagios@ats-db-04 plugins]$ ./test2
As for the nrpe version on the rhel box I am using the standalone version I believe. It is the one that you can install from EPEL.
yum list installed nrpe
nrpe.x86_64     3.2.0-6.el7         @epel
npolovenko
@danielgaraventa_ats, Actually, I think your version of nrpe runs checks under nrpe user. You can make sure by opening /usr/local/nagios/nrpe.cfg file, and looking for the lines that say nrpe_user= and nrpe_group=
The first thing you could try is to create a script on the remote server that will call the test2 script and put its output to a local text file ./test2 >1.txt. Then you'd run the parent script with nrpe. That way you will get to know whether results get lost during NRPE transaction or maybe nrpe user still has permission problems. Or I guess you could just save $OUT to a local text file. But I hope you get my point?
Also, you may give this a shot:
  su - nrpe
./test2
Keep us updated.
danielgaraventa_ats
I stripped down the script to be the following. Taking the SQL command out just for testing purposes.
#!/bin/bash
UNKNOWN=3
CRIT=2
WARN=1
OK=0
OUTTEST=`cat test.txt`
export OUTTEST
if test "$OUTTEST" -gt 30; then
  echo "OK - Passwords are not set to expire for another "$OUTTEST" days"
  exit $OK
elif test "$OUTTEST" -gt 14; then
  echo "WARN - Passwords are scheduled to expire in "$OUTTEST" days"
  exit $WARN
else
  echo "CRIT - Passwords are scheduled to expire in "$OUTTEST" days"
  exit $CRIT
fi
test.txt contains the number 90. Running the script locally I see this.
[nrpe@svr-rhel7 plugins]$ ./test2
Running the test from our Nagios server via nrpe the 90 is not populated.
Daniel
danielgaraventa_ats
I forgot to add test.txt is owned by nrpe and I change the permissions to 777.
Daniel
npolovenko
@danielgaraventa_ats, If you change this line in the script:
to
OUTTEST=`cat /full/path/to/test.txt`
Then it's going to work. I think the main problem with your original script is that sqlplus runs as a sudo, or as a nagios user but it doesn't run as nrpe user. Either because the nrpe user doesn't have a shell, or because of the other permissions problem. Sometimes you also need to include environment variables in order for the script to run.
danielgaraventa_ats
I believe I found the issue. I added the following the the script and I am now getting results back.
ORACLE_BASE=/opt/oracle
ORACLE_HOME=$ORACLE_BASE/product/11.2.0.4
export ORACLE_BASE ORACLE_HOME
Thank you for all your help! I will mark this post as solved.
Daniel
