MongoDB Database Monitoring
jkinning
Post by jkinning »
I am still trying to get monitoring going for some external MongoDB databases. I had our firewall guys open up the necessary ports and I appear to be able to connect now but getting Username/Password incorrect and I know they are right.
./check_mongodb.py -H ds028797-a1.krf74.fleet.mongolab.com -P 12345 -u username_masked -p password_masked -d mc-5940133d-bf07-4545-a704-ef49d24e8a1a-trackingcontact
From what I can tell I am using the correct syntax. Not sure what to try next.
npolovenko
Re: MongoDB Database Monitoring
Post by npolovenko »
Hello, @jkinning. Are there any special characters used in the password? If so, please put the password in single quotes. What version of mongoDB are you running?
Try to nmap the mongoDB port from the Nagios server:
nmap ds028797-a1.krf74.fleet.mongolab.com -p1235
Make sure that authentication is enabled on MongoDB server https://docs.mongodb.com/manual/tutoria ... ntication/
Also, you may be able to find some more information on what exactly goes wrong in mongodb log file.
jkinning
Post by jkinning »
I am still struggling to get this to work.
Here is what the logs show:
2018-01-11T11:23:24.664-0800 I NETWORK  [initandlisten] connection accepted from 207.242.44.6:11122 #51743 (11 connections now open)
2018-01-11T11:23:24.744-0800 I NETWORK  [initandlisten] connection accepted from 207.242.44.6:11143 #51744 (12 connections now open)
2018-01-11T11:23:24.792-0800 I ACCESS   [conn51744] SCRAM-SHA-1 authentication failed for scadmin on admin from client 207.242.44.6 ; UserNotFound Could not find user scadmin@admin
2018-01-11T11:23:24.815-0800 I NETWORK  [conn51744] end connection 207.242.44.6:11143 (11 connections now open)
2018-01-11T11:23:24.815-0800 I NETWORK  [conn51743] end connection 207.242.44.6:11122 (10 connections now open)
When the Developer is testing this with Robo3t here is what his settings are, pic1,pic2, and pic3.
When I validate with nmap things look alright:
nmap ds038327-a1.krf74.fleet.mongolab.com -p38322
Starting Nmap 6.47 ( http://nmap.org ) at 2018-01-12 07:49 EST
Nmap scan report for ds038327-a1.krf74.fleet.mongolab.com (52.170.221.52)
Host is up (0.0031s latency).
PORT      STATE SERVICE
38322/tcp open  unknown
Nmap done: 1 IP address (1 host up) scanned in 0.34 seconds
But when I try to run from Nagios I get the same thing.
npolovenko
@jkinning, Can you try using the plugin in the attachment instead? Does it fix the issue?
Also, I'd try to put single quotes around the username and, maybe the password as well.
Was this line taken from a MongoDB server-side log?It says it couldn't find the username "scadmin@admin". But whenever you test the connection with this username everything works as it should, right?
jkinning
Post by jkinning »
I am using the new check_mongodb.pl script you provide and still get the same problem.
Yes when using Robo3t we are able to connect to the instance. I even tried to use the username@instance but still the same result.
npolovenko
@jkinning, It could be an authentication mechanism issue. I think MONGODB-CR used to be a default authentication method for MongoDB until recently, and now its CRAM-CHA. I will try to spin up a MongoDB server in the lab in the next couple of days. But in a meantime, you could always ask the author of this plugin directly on a Github page, and I believe he also left his email address for questions.
https://github.com/mzupan/nagios-plugin-mongodb
jkinning
Post by jkinning »
I've reached out to the plugin author via email but just hearing crickets.
You get a chance to test this in your lab?
npolovenko
@jkinning, I tested out this plugin with my own instance of MongoDB hosted on the mlab. And I've got exactly the same error you had. So I went ahead and submitted an internal bug report. You may be able to find another, working plugin on the Nagios Exchange while they release a fix for this one. https://exchange.nagios.org/index.php?o ... rd=mongodb
Thank you.
jkinning
Post by jkinning »
I looked over the list and tried out a couple but couldn't find one where I can specify a different port.
I have tried these:
https://exchange.nagios.org/directory/Plugins/Databases/Others/Check-MongoDB/details
https://tag1consulting.com/blog/mongodb-nagios-check
this one I couldn't get much going, disclaimer I am not a MongoDB expert, so when I got it installed and tried different commands based of the syntax on the site I kept getting this message.
./check_mongo
./check_mongo: line 30: import: command not found
./check_mongo: line 31: import: command not found
./check_mongo: line 32: import: command not found
./check_mongo: line 34: try:: command not found
./check_mongo: line 35: from: command not found
./check_mongo: line 36: except: command not found
./check_mongo: line 37: from: command not found
./check_mongo: line 42: syntax error near unexpected token `('
./check_mongo: line 42: `def main(argv):'
Any other thoughts or ideas to get these MongoDB monitored with Nagios XI? Doesn't appear to be much out there for Nagios XI but did look over the XI guide on how to monitor and it is using the same plugin that I am having an issue with.
npolovenko
@jkinning, Would you consider downgrading the MongoDB version? You could possibly open a support ticket to get assistance with that.
