Error w/ localhost - HTTP WARNING: HTTP/1.1 403 Forbidden
PhilG
Post by PhilG »
Hello:
Using Oracle Enterprise Linux 7.3, latest install of Nagios XI installed (ver. 5.4.11).
First thing I see in the web console is localhost doing a check_http and getting error:
I did some checking around and found the following, but they didn't help fix the warning/issue:
1). http://raman-kumar.blogspot.com/2009/12 ... 1-403.html
2). https://serverfault.com/questions/52934 ... 60-seconds
3). https://support.nagios.com/forum/viewto ... en#p201859
4). https://serverfault.com/questions/52183 ... nux/521834
I did some digging around and found that localhost uses:
/usr/local/Nagios/etc/services/localhost.cfg
which has:
host_name localhost
service_description HTTP
use local-service
check_command check_http
SSH'ed into the new Nagios XI server as root and then ran the following from the command line and result is as follows:
a). /usr/local/nagios/libexec/check_http -H <new_nagiosxi_server_IP>
Result: HTTP WARNING: HTTP/1.1 403 Forbidden
b). /usr/local/nagios/libexec/check_http -H <new_nagiosxi_server_IP> -u "/nagiosxi"
Result: HTTP OK: HTTP/1.1 301 Moved Permanently
c). /usr/local/nagios/libexec/check_http -H <any_website, ex. google.com or internal website we host>
SOLUTION: "Re-engineered" NagiosXI localhost check_http temporarily until a possible better "fix" is identified.
1). Stopped Apache and NagiosXI on server
2). Edited the "/usr/local/nagios/etc/services/localhost.cfg" file:
a). Changed the following:
commented out: use local-service
added: use xiwizard_website_http_service
added: contacts nagiosadmin
commented out: check_command check_http
added: check_command check_xi_service_http! -f ok -I <new_nagiosxi_server_IP> -u '/nagiosxi' -p 80
Either I leave this, or wait for a solution from Nagios XI tech team, or delete the localhost check, since if I can connect/access the Nagios XI web console, then Apache is working at least.
Newbie '14
npolovenko
Re: Error w/ localhost - HTTP WARNING: HTTP/1.1 403 Forbidde
Post by npolovenko »
Hello,@PhilG. Thanks for your input! You might have some firewall restrictions in your organisation that interfere with check_http. But first, lets try the following:
SSH into the Nagios XI and run this command:
/usr/local/nagios/libexec/check_http -I 127.0.0.1
And this command:
/usr/local/nagios/libexec/check_http -H <new_nagiosxi_server_IP> -u "/nagiosxi/"
Finally, this command:
/usr/local/nagios/libexec/check_http -H www.google.com
When I ran check_http against google.com I also got "Moved Permanently", but then I ran it with www and got the right result.
Please provide us with the output. Thank you.
PhilG
Post by PhilG »
npolovenko wrote:Hello,@PhilG. Thanks for your input! You might have some firewall restrictions in your organisation that interfere with check_http. But first, lets try the following:
And this command:
I'm redoing the server at this time and am leaving home for the day in a few minutes. It appears that what I noted earlier and applied may have affected with getting back on the Nagios XI web console, so I reverted to my base server VM snapshot and ran the NagiosXI full install again. *sigh*
To answer the issue about a firewall problem, I do not believe so. If there was a firewall issue, then I would have received errors or not have been able to check any "external" sites. The new server is not running IPTables/local firewall, too. The problem is ONLY occurring with localhost attempting to check_http on local server Apache/http.
Install completed and got back on Nagios XI console. I have not added/deleted/modified anything yet on the server and in the Nagios XI web console (other than the Admin password and time). Here's the information you wanted from the server command line:
1). /usr/local/nagios/libexec/check_http -I 127.0.0.1
2). /usr/local/nagios/libexec/check_http -H <new_nagiosxi_server_IP> -u "/nagiosxi/"
3). /usr/local/nagios/libexec/check_http -H google.com
4). /usr/local/nagios/libexec/check_http -H http://www.google.com
Result: HTTP OK: HTTP/1.1 200 OK
5). /usr/local/nagios/libexec/check_http -H <FQDN of "internally" hosted website on a different Apache server>
Newbie '14
PhilG
Post by PhilG »
I believe I have this figured out. A piece of information from the following gave me a clue:
https://stackoverflow.com/questions/236 ... -forbidden
My OEL 7.3 Apache web server template contained a "default" Virtual Host file that had the document root to "/var/www/html", which is owned by "root" user and group. Obviously, "localhost" does not have the privilege.
SOLUTION: Removed "default" Virtual Host on server and restarted Apache and Nagios. Now the localhost check_http is fine.
Once again, I needed to refer to the term "BASE" (bare bones) server install, step back, and then take a little time to reflect what exists and check things over more closely.
You may lock this post.
Newbie '14
Thanks for the feedback, PhilG!
