Started this morning with original version 2011R1.3
Downloaded and installed what I thought was 2011R1.9 but grabbed 2009R1.4B by mistake
The 2009R1.4B installed successfully...realized only when Nagiosxi version showed 2009R1.4B
I downloaded 2011R1.3 and installed..the logs displays that it upgraded successfully...
Nagiosxi still displays version 2009R1.4B after logon (after sucessful upgrade to 2011R1.3)?
I restarted httpd and nagios but no luck. older version still displays
Do I need to re-run the upgrade? Attached are the upgrade logs for the 2011R1.3
2011R1.9 upgrade problem
Re: 2011R1.9 upgrade problem
Yeah I would start with clearing the /tmp/nagiosxi directory, extracting the tarball and re-running the upgrade. Lets start with that and see what needs to be done from there.
No dice... The upgrade now takes longer during the pre-flight inspection and I recieved an error stopping nagios service "the service took an unexpectdly long time to stop" message. The nagios service restart looked to be stalled and it never restarted during the upgrade.... Because of time I recovered from a snapshot prior to the first install and am now back on 2011R1.3. Is there by chance a download link available for 2001R1.6? I want to get SSL up and running which requires 1.6 or above.
You can find the 2011R1.6 release here. Is there some reason you don't want to upgrade to the latest 2011R1.9 while you're going through all this trouble?
Will try upgrade to 1.9 later this month..thank you for the link
