How can I see all the results returned (as typically depicted in the time graph) and not the first 250 that are available for paging?
I know that it will make things slower but primarily I am interested in
- any pie or bar graphs that I make being indicative of the full search
- my csv export being the full search
All results and not first 250
Re: All results and not first 250
Click the Configure icon(gear looking thing) in the top right of the panel and go to the paging tab. There isn't an "all" option but you can set the Per Page and Page limit options so that it returns a lot more than 250 results.
billy_strath
Cheers. Is there an upper limit? I'm on a 4 node cluster and if I set to 100 x 100 it returns zero
Nothing hardcoded, but if it's not able to allocate enough memory for the results it will return 0. The max for the system is 64GB.
- Former Nagios Staff
I tried 100 x 100 just as a test to make sure there wasn't something screwy going on with those particular numbers, and got 10000 as expected. It's probably the RAM.
