Map doesn't work
t3dus
Map doesn't work
Post by t3dus »
I have a nagios server on a VPS server and everything is working just fine except the map..
The map has this error. I'm not exactly sure how to fix it.
map error.PNG (7.83 KiB) Viewed 2915 times
Re: Map doesn't work
Post by dwhitfield »
What info, if any, does it show when you click the "here" for more info? It looks like the map is not able to see the nagios process, but if everything else is working it does make a lot of sense.
What's the output of:
service nagios status
sestatus
ps -aef | grep nagios.cfg
Please put the output in a code block (or blocks). The "Code" button is the fifth from the left on the post input screen (between Quote and List).
t3dus
Post by t3dus »
dwhitfield wrote:What info, if any, does it show when you click the "here" for more info? It looks like the map is not able to see the nagios process, but if everything else is working it does make a lot of sense.
sestatus
# service nagios status
â— nagios.service - LSB: Example initscript
   Loaded: loaded (/etc/init.d/nagios; bad; vendor preset: enabled)
   Active: active (running) since Mon 2018-02-05 21:13:54 EST; 2 weeks 1 days ago
     Docs: man:systemd-sysv-generator(8)
  Process: 13827 ExecStop=/etc/init.d/nagios stop (code=exited, status=0/SUCCESS)
  Process: 13854 ExecStart=/etc/init.d/nagios start (code=exited, status=0/SUCCESS)
   CGroup: /system.slice/nagios.service
           ├─13862 /usr/local/nagios/bin/nagios -d /usr/local/nagios/etc/nagios.cfg
           ├─13863 /usr/local/nagios/bin/nagios --worker /usr/local/nagios/var/rw/nagios.qh
           ├─13864 /usr/local/nagios/bin/nagios --worker /usr/local/nagios/var/rw/nagios.qh
           ├─13865 /usr/local/nagios/bin/nagios --worker /usr/local/nagios/var/rw/nagios.qh
           ├─13866 /usr/local/nagios/bin/nagios --worker /usr/local/nagios/var/rw/nagios.qh
           ├─13867 /usr/local/nagios/bin/nagios --worker /usr/local/nagios/var/rw/nagios.qh
           ├─13868 /usr/local/nagios/bin/nagios --worker /usr/local/nagios/var/rw/nagios.qh
           └─13869 /usr/local/nagios/bin/nagios -d /usr/local/nagios/etc/nagios.cfg
# sestatus
-bash: sestatus: command not found
# ps -aef | grep nagios.cfg
nagios   13862     1  0 Feb05 ?        00:07:10 /usr/local/nagios/bin/nagios -d /usr/local/nagios/etc/nagios.cfg
nagios   13869 13862  0 Feb05 ?        00:01:04 /usr/local/nagios/bin/nagios -d /usr/local/nagios/etc/nagios.cfg
root     29998 29664  0 14:41 pts/0    00:00:00 grep --color=auto nagios.cfg
wow this is a month old, are you still experiencing the same problem with the map and have you all along? This can happen if the pid is not being updated properly.
What version of Nagios are you running?
t3dus
Post by t3dus »
scottwilkerson wrote:wow this is a month old, are you still experiencing the same problem with the map and have you all along? This can happen if the pid is not being updated properly.
Still having it. I just forgot to update the topic. Nagios Core 4.3.4
When you click the "here" link in the error message what do you see?
Sorry but I cannot replicate this
